danswatman
  1. So I still can not find the irrigation module.....
  2. Where would the irrigation module appear? I purchased it but I can't seem to find it after updating modules? Thanks, Dan
  3. So, after what seems to be a sucesaful upgrade I can not conect to the unit via java console, I can get to it via telnet. If I use the web download client I get an error which says something like socket open failed javax.net.ssl....... The best error seems to be the lights on the isy which occasionaly the red error like come on,, then a bit latter the green memory light and then both of them. Seems my isy is sick what is the best course of action? Thanks, Dan
  4. Upgrade went fine for me. Is there upcoming ELK support in this series of updates? Thanks, Dan[/b]
  5. It does fix those status's such as the ezflora which does not report status properly.
  6. danswatman posted a topic in ISY994
    So the "manual" defines the query command as (Query - triggers the ISY to check an "ISY node" for status) I;m thinking that should be more like "insteon point" but my main question is what's the use of the command other than to correct status which may be whacked out? I know it forces the status to be written to the log which is interesting for troubleshooting but what else? Is there some secret purpose to the command? Cheers, Dan
  7. I also have had these problems, eventually I was able to get it to go, only with wired machine one foot in air and hands out front Same for me, I have tried two different Macs, both running Snow Leopard, both error out saying "Invalid Length", even though the .zip extracts fine on the host. One machine made it 13%, the other made it a little further, but still got the same error. http://www.flickr.com/photos/wheelpics/4483581398/
  8. danswatman posted a topic in ISY994
    Great work but I would also caution any automatic actions by a garage door. Even with the sensor beam. I know closing or opening the door with my car's hatch up can result in really bad things happening. I also had a box get caught up on a side shelf that had it gone unnoticed it would have caused significant damage. Still great work on the concept Cheers, Dan
  9. ok the label on the RL say 1.1 on the same label as the address, look new also because its a sticker on top of the existing label. This is again a new RL I just received.
  10. Not sure what you mean by firmware revision isy reports it..??. it says v.00 when the RL is selected but so does my old RL. The RL does program in that special mode you mention which leads me to believe that once the isy knows the device is an i2 the isy is able to program the RL fine. Cheers, Dan
  11. Looks like you are correct the new RL which this one is seems to do fine in that device reported mode, which seems to be i2. Using that option the link works fine. no problem with the slow reply I had pretty much decided this was a bit more than I wanted to tackle at the mommet... I did get my insteon venstar installed though.... 2009/05/23 09:16:03 : [0A.31.0A.1] Start : Adding to scene 'Kitchen Main Lights' 2009/05/23 09:16:03 : [0A.31.0A.1] Making PLM a Responder to group 1 2009/05/23 09:16:03 : [MNG-LNK-RSP ] 02 6F 41 A2 01 0A 31 0A 00 05 00 15 2009/05/23 09:16:03 : [0A.31.0A.1] Making 'Kitchen:Main Lights Right' a Responder 2009/05/23 09:16:03 : [A 31 A 1] Querying engine version 2009/05/23 09:16:04 : [iNST-ACK ] 02 62 0A.31.0A 0F 0D 00 06 (00) 2009/05/23 09:16:04 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 0D 01 (01) 2009/05/23 09:16:04 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:04 : [A 31 A 1] Retrieved engine version is i2 2009/05/23 09:16:04 : [0A.31.0A.1] Using engine version i2 2009/05/23 09:16:04 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 00 06 (00) 2009/05/23 09:16:05 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00) 2009/05/23 09:16:05 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:06 : [iNST-ERX ] 02 51 0A 31 0A 0F D4 07 12 2F 00 00 01 0F B7 01 00 00 00 00 00 00 00 00 00 2009/05/23 09:16:06 : [Extended-Direct][0A.31.0A-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 2009/05/23 09:16:06 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 02 0F B7 08 E2 01 11 6C CF 00 00 01 00 06 (00) 2009/05/23 09:16:07 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00) 2009/05/23 09:16:07 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:07 : [11 6C CF 1] Querying engine version 2009/05/23 09:16:07 : [iNST-ACK ] 02 62 11.6C.CF 0F 0D 00 06 (00) 2009/05/23 09:16:08 : [iNST-SRX ] 02 50 11.6C.CF 0F.D4.07 2B 0D 01 (01) 2009/05/23 09:16:08 : [standard-Direct Ack][11.6C.CF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:08 : [11 6C CF 1] Retrieved engine version is i2 2009/05/23 09:16:08 : [Kitchen] Using engine version i2 2009/05/23 09:16:08 : [iNST-ACK ] 02 62 11.6C.CF 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 00 06 (00) 2009/05/23 09:16:08 : [iNST-SRX ] 02 50 11.6C.CF 0F.D4.07 2B 2F 00 (00) 2009/05/23 09:16:09 : [standard-Direct Ack][11.6C.CF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:09 : [iNST-ERX ] 02 51 11 6C CF 0F D4 07 11 2F 00 01 01 0F C7 01 00 00 00 00 00 00 00 00 00 2009/05/23 09:16:09 : [Extended-Direct][11.6C.CF-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 2009/05/23 09:16:09 : [iNST-ACK ] 02 62 11.6C.CF 1F 2F 00 00 02 0F C7 08 A2 01 0A 31 0A FF 1F 01 00 06 (00) 2009/05/23 09:16:09 : [iNST-SRX ] 02 50 11.6C.CF 0F.D4.07 2B 2F 00 (00) 2009/05/23 09:16:09 : [standard-Direct Ack][11.6C.CF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:09 : [0A.31.0A.1] Making 'Kitchen:Main Lights Left' a Responder 2009/05/23 09:16:09 : [0A.31.0A.1] Using engine version i2 2009/05/23 09:16:10 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 00 06 (00) 2009/05/23 09:16:10 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00) 2009/05/23 09:16:11 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:11 : [iNST-ERX ] 02 51 0A 31 0A 0F D4 07 12 2F 00 00 01 0F AF 01 00 00 00 00 00 00 00 00 00 2009/05/23 09:16:11 : [Extended-Direct][0A.31.0A-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 2009/05/23 09:16:11 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 02 0F AF 08 E2 01 11 6A 06 00 00 01 00 06 (00) 2009/05/23 09:16:12 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00) 2009/05/23 09:16:12 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:12 : [11 6A 6 1] Querying engine version 2009/05/23 09:16:12 : [iNST-ACK ] 02 62 11.6A.06 0F 0D 00 06 (00) 2009/05/23 09:16:12 : [iNST-SRX ] 02 50 11.6A.06 0F.D4.07 2B 0D 01 (01) 2009/05/23 09:16:12 : [standard-Direct Ack][11.6A.06-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:12 : [11 6A 6 1] Retrieved engine version is i2 2009/05/23 09:16:12 : [Kitchen] Using engine version i2 2009/05/23 09:16:12 : [iNST-ACK ] 02 62 11.6A.06 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 00 06 (00) 2009/05/23 09:16:13 : [iNST-SRX ] 02 50 11.6A.06 0F.D4.07 2B 2F 00 (00) 2009/05/23 09:16:13 : [standard-Direct Ack][11.6A.06-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:13 : [iNST-ERX ] 02 51 11 6A 06 0F D4 07 11 2F 00 01 01 0F C7 01 00 00 00 00 00 00 00 00 00 2009/05/23 09:16:13 : [Extended-Direct][11.6A.06-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 2009/05/23 09:16:13 : [iNST-ACK ] 02 62 11.6A.06 1F 2F 00 00 02 0F C7 08 A2 01 0A 31 0A FF 1F 01 00 06 (00) 2009/05/23 09:16:14 : [iNST-SRX ] 02 50 11.6A.06 0F.D4.07 2B 2F 00 (00) 2009/05/23 09:16:14 : [standard-Direct Ack][11.6A.06-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:14 : [0A.31.0A.1] Making 'Hallway:Control A' a Responder 2009/05/23 09:16:14 : [0A.31.0A.1] Using engine version i2 2009/05/23 09:16:14 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 00 0F A7 01 00 00 00 00 00 00 00 00 00 06 (00) 2009/05/23 09:16:15 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00) 2009/05/23 09:16:15 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:15 : [iNST-ERX ] 02 51 0A 31 0A 0F D4 07 11 2F 00 00 01 0F A7 01 00 00 00 00 00 00 00 00 00 2009/05/23 09:16:15 : [Extended-Direct][0A.31.0A-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 2009/05/23 09:16:15 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 02 0F A7 08 E2 01 07 98 0F 00 00 01 00 06 (00) 2009/05/23 09:16:16 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00) 2009/05/23 09:16:16 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:16 : [7 98 F 1] Querying engine version 2009/05/23 09:16:16 : [iNST-ACK ] 02 62 07.98.0F 0F 0D 00 06 (00) 2009/05/23 09:16:16 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 0D 00 (00) 2009/05/23 09:16:16 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:16 : [7 98 F 1] Retrieved engine version is i1 2009/05/23 09:16:16 : [Hallway] Using engine version i1 2009/05/23 09:16:16 : [iNST-ACK ] 02 62 07.98.0F 0F 28 0F 06 SET-MSB(0F) 2009/05/23 09:16:16 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 28 0F SET-MSB(0F) 2009/05/23 09:16:17 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:17 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 60 06 PEEK (60) 2009/05/23 09:16:17 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 27 2B 00 PEEK (00) 2009/05/23 09:16:17 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:17 : [iNST-ACK ] 02 62 07.98.0F 0F 29 A2 06 POKE (A2) 2009/05/23 09:16:17 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 A2 POKE (A2) 2009/05/23 09:16:17 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:18 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 61 06 PEEK (61) 2009/05/23 09:16:18 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00) 2009/05/23 09:16:18 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:18 : [iNST-ACK ] 02 62 07.98.0F 0F 29 01 06 POKE (01) 2009/05/23 09:16:19 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 01 POKE (01) 2009/05/23 09:16:19 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:19 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 62 06 PEEK (62) 2009/05/23 09:16:19 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00) 2009/05/23 09:16:19 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:19 : [iNST-ACK ] 02 62 07.98.0F 0F 29 0A 06 POKE (0A) 2009/05/23 09:16:19 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 0A POKE (0A) 2009/05/23 09:16:19 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:20 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 63 06 PEEK (63) 2009/05/23 09:16:20 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 27 2B 00 PEEK (00) 2009/05/23 09:16:20 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 2009/05/23 09:16:20 : [iNST-ACK ] 02 62 07.98.0F 0F 29 31 06 POKE (31) 2009/05/23 09:16:20 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 31 POKE (31) 2009/05/23 09:16:20 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:21 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 64 06 PEEK (64) 2009/05/23 09:16:21 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00) 2009/05/23 09:16:21 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:21 : [iNST-ACK ] 02 62 07.98.0F 0F 29 0A 06 POKE (0A) 2009/05/23 09:16:21 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 0A POKE (0A) 2009/05/23 09:16:21 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:22 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 65 06 PEEK (65) 2009/05/23 09:16:22 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00) 2009/05/23 09:16:22 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:22 : [iNST-ACK ] 02 62 07.98.0F 0F 29 FF 06 POKE (FF) 2009/05/23 09:16:22 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 FF POKE (FF) 2009/05/23 09:16:22 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:23 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 66 06 PEEK (66) 2009/05/23 09:16:23 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00) 2009/05/23 09:16:23 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:23 : [iNST-ACK ] 02 62 07.98.0F 0F 29 1F 06 POKE (1F) 2009/05/23 09:16:24 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 1F POKE (1F) 2009/05/23 09:16:24 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:24 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 67 06 PEEK (67) 2009/05/23 09:16:24 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00) 2009/05/23 09:16:24 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:24 : [iNST-ACK ] 02 62 07.98.0F 0F 29 03 06 POKE (03) 2009/05/23 09:16:24 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 03 POKE (03) 2009/05/23 09:16:25 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 2009/05/23 09:16:25 : [0A.31.0A.1] Finish : Adding to scene 'Kitchen Main Lights' was Successful 2009/05/23 09:16:40 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00) 2009/05/23 09:16:40 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1 2009/05/23 09:16:40 : [ A 31 A 4] DON 0 2009/05/23 09:16:40 : [ A 31 A 4] ST 255 2009/05/23 09:16:41 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00) 2009/05/23 09:16:41 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1 2009/05/23 09:16:41 : Duplicate: ignored 2009/05/23 09:16:41 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00): Process Message: failed 2009/05/23 09:16:41 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1 2009/05/23 09:16:41 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 41 11 04 LTONRR (04) 2009/05/23 09:16:41 : [standard-Cleanup][0A.31.0A-->ISY/PLM Group=4] Max Hops=1, Hops Left=0 2009/05/23 09:16:42 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00) 2009/05/23 09:16:42 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1 2009/05/23 09:16:42 : [ A 31 A 4] DON 0 2009/05/23 09:16:42 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00) 2009/05/23 09:16:42 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1 2009/05/23 09:16:42 : Duplicate: ignored 2009/05/23 09:16:42 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00): Process Message: failed 2009/05/23 09:16:42 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1 2009/05/23 09:16:43 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 41 11 04 LTONRR (04) 2009/05/23 09:16:43 : [standard-Cleanup][0A.31.0A-->ISY/PLM Group=4] Max Hops=1, Hops Left=0
  12. I believe mine is in the programing mode??? by the holding of bright and dim and then getting the blinking light? Anyway it now seems to have the below issue when being added to any scenes.... 2009/05/19 21:09:36 : [0A.31.0A.2] Start : Adding to scene 'Hallway Lights' 2009/05/19 21:09:36 : [0A.31.0A.2] Making PLM a Responder to group 2 2009/05/19 21:09:36 : [MNG-LNK-RSP ] 02 6F 41 A2 02 0A 31 0A 00 05 00 15 2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Main' a Responder 2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Control' a Responder 2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Bottom Stair' a Responder 2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Far Switch' a Responder 2009/05/19 21:09:36 : [0A.31.0A.2] Using engine version i1 2009/05/19 21:09:36 : [iNST-ACK ] 02 62 0A.31.0A 0F 28 0F 06 SET-MSB(0F) 2009/05/19 21:09:44 : [iNST-ACK ] 02 62 0A.31.0A 0F 28 0F 06 SET-MSB(0F) 2009/05/19 21:09:51 : [iNST-ACK ] 02 62 0A.31.0A 0F 28 0F 06 SET-MSB(0F) 2009/05/19 21:09:53 : [0A.31.0A.2] Finish : Adding to scene 'Hallway Lights' was Incomplete
  13. No luck so far with any of those methods.... I have this in the log: 2009/05/18 21:06:36 : CLI-WBug: Successfully Processed WBug Response 2009/05/18 21:06:41 : ---- Initializing the linked devices ---- 2009/05/18 21:06:41 : ---- All Linked Devices are now initialized ---- 2009/05/18 21:06:41 : ---- Add remaining devices ---- 2009/05/18 21:06:41 : [ A0 31 A0 1] Removing all links 2009/05/18 21:06:41 : [A0 31 A0 1] Querying engine version 2009/05/18 21:06:41 : [iNST-ACK ] 02 62 A0.31.A0 0F 0D 00 06 (00) 2009/05/18 21:06:46 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0 2009/05/18 21:06:46 : CLI-WBug: Successfully Processed WBug Response 2009/05/18 21:06:48 : [iNST-ACK ] 02 62 A0.31.A0 0F 0D 00 06 (00) 2009/05/18 21:06:55 : [iNST-ACK ] 02 62 A0.31.A0 0F 0D 00 06 (00) 2009/05/18 21:06:56 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0 2009/05/18 21:06:56 : CLI-WBug: Successfully Processed WBug Response 2009/05/18 21:06:57 : [A0 31 A0 1] Failed getting engine version. Reverting to i1. 2009/05/18 21:06:57 : [] Using engine version i1 2009/05/18 21:06:57 : [iNST-ACK ] 02 62 A0.31.A0 0F 28 0F 06 SET-MSB(0F) 2009/05/18 21:07:04 : [iNST-ACK ] 02 62 A0.31.A0 0F 28 0F 06 SET-MSB(0F) 2009/05/18 21:07:06 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0 2009/05/18 21:07:06 : CLI-WBug: Successfully Processed WBug Response 2009/05/18 21:07:11 : [iNST-ACK ] 02 62 A0.31.A0 0F 28 0F 06 SET-MSB(0F) 2009/05/18 21:07:13 : [ A0 31 A0 1] ** Not added ** Remove Device Links failed 2009/05/18 21:07:13 : ---- All Remaining Device Added ----
  14. Seems the ISY is not able to resolve the name. I'd verify the DHCP settings its getting. I set mine for static address I don't think having it move about is a good idea? Cheers, Dan
  15. I also get the error trying to install a second remotlinc.... I only have about 50 devices.
