RKinOhio
  1. Interestingly, the system is now working as it should with the only noted change being that the log now shows the correct time. It is no longer in DST. Thank you. Randy
  2. Starting on Sunday, my eisy programs stopped controlling my KASA devices. Working through the admin console, the devices are not accurately showing their current status on all devices and none of them are responding to commands from the console although the KASA controller shows that it is connected and which devices are connected. I have seen a condition in which the KASA controller becomes disconnected (not certain as to why but we have lost power on occasion), but everything would be restore after going to Polyglot, shutting down the KASA plugin, and starting it again. I don't see any sign of errors or warnings in the log files. When I send a command to a KASA device near my desk from the console the 'DON' and 'DOF' followed by "node address ********3e34 does not exist." and I have noticed that the plugin clock is still running on DST while the admin console time is correct. After looking for other topics similar to this issue, I have tried unplugging and re-plugging the devices, restarting the plugin, and rebooting the eisy. All of the packages are up-to-date. I haven't made any changes in months to my programs, devices or network. Any ideas as to what may be going on? Thanks, Randy
  3. No, I didn't, but when I just went in to edit the current IoX configurations, I noticed that the address is set for the 127.0.0.1 and the HTTP/S was set for HTTPS. I selected the HTTP and within a few seconds I was connected on both the admin console and the P3x. That worked. Thanks for the suggestion to look. I wouldn't have thought of it without your prompting to look. Thank you! I think that I am good now.
  4. Everything had been running smoothly until I went to add a pair of KASA modules. I noticed the packages needed updating so I did the update and two reboots, re-installed the node server(s) on the Polyglot (System - Reinstall) and noticed that the IoX was shown as disconnected now on Polyglot 3. The nodeserver was not online on the admin console. Re-booted a couple of times, powered it down twice, repeated the initial steps and I still don't have a connection. Also, is it normal for the IoX Launcher to locate the ISY and still have the Finder say "Not Found"? Helpful insight would be appreciated. Thanks!
  5. Just saw your note. I was getting ready to send you an update. I took a tip from Techman (Michael?) and powered the eisy off, then restarted. I am now running 5.6.2. Thanks to you both! RK
  6. Thanks, Dennis. I tried the update and I am still at 5.6.0. Any other thoughts? Randy
  7. That sounds like a good suggestion. Thank you.
  8. For some reason, I have not been able to get the 'update packages' to update anything. I have tried repeatedly with both the reboot button and the power pulled. I am tempted to restore an earlier configuration and see if that will allow me to update. Do you have an other suggestions?
  9. No. This is my first and only so far. Thanks.
  10. As I started working with the Polyglot this afternoon, I noticed that my KASA node server was showing the IoX as disconnected. I have tried logging off and on, rebooting the eisy, rebooting the eisy with the power cord and numerous other groupings, but it is still not connected. Am I missing something else for my bag of tricks and tips? Thanks, RK
  11. I pulled the power and verified that I am 5.6 on both the UI and the eisy. I can now get into the Polyglot! Thank you for your help. I will add that to my bag of tricks. RK
  12. Yes, I have access to the devices and programs. The programs are running as expected. I rebooted the eisy and there was no change in the Polyglot login. Press the button and nothing happens. After reboot I confirmed that the devices are working normally, except for the KASA devices. I can turn bulbs on and off, but the information in the administrative console is empty. I truly appreciate the help and ideas. RK
  13. I need some new ideas. My old ones haven't worked. I replaced my router with a eero mesh system. My eisy has an IP reservation and I have no problems launching into it. I can access the ISY portal without issues. When I try to go into the Polyglot v3 from either the launcher or from the Administrative Console, the logon screen comes up, I enter my credentials, press the login button and nothing happens. I have tried the Incognito mode on Chrome and tried using Microsoft Edge without luck. Given that when I was using my old router there were no problems, I am wondering what is different with the eero router. Maybe the router isn't the problem. I am open to anything. I am probably just overlooked something. Any suggestions? Thanks. RK
  14. Same sensor, but a different question. I have a 2844-222 running through the ISY at v4.6.2. A program reacts to the motion 'on' signal to control a light between dusk and dawn; the program sets the on time. What I don't know is if the 2844-222 will send a 'low bat' signal that the ISY can read. If it does, I can send a text message indicating that it is time to change the battery. Has anyone worked with the 2844-222, ISY at 4.6.2 and the 'low bat' signal? What did you find? Thanks, RK
