drs4life
  1. I'm good now, Thanks. seems F/W was the issue, as mine too several hard resets & finally completed.. But It wiped out my config. no worries though.
  2. Portal states "offline/registered". Tried refreshing & rebooting to no avail.
  3. Fixed, it was all due to the wrong date. I finally got the date cmd to run & now it all works
  4. excerpt for sudo pkg update: [admin@polisy ~]$ sudo pkg update Password: Updating FreeBSD-base repository catalogue... Certificate verification failed for /C=US/O=Let's Encrypt/CN=R3 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /C=US/O=Let's Encrypt/CN=R3 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /C=US/O=Let's Encrypt/CN=R3 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /C=US/O=Let's Encrypt/CN=R3 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915:
  5. I'm using chrome with latest updates. I tried both hard reset (3x flashing lights) & single button press which didn't seem to do anything. I also tried manual upgrade <sudo pkg update, sudo pkge upgrade & sudo service pg3 restart> but it throws allot of errors & doesn't update.
  6. when I try that, It immediately redirects me back to the login scn.
  7. new to polisy: after following initial start process, I was able to log into polisy PG3 but I get no dashboard. it states i have logged in but remains on the login screen. i also noticed that the date is way off (2017) via ssh "date" cmd. I made sure timezone is correct & tried "sudo date 220516" but it doesnt work. I tried factory resetting polisy but still nogo. sudo uname -r <13.0-RELEASE-p11>
  8. I'm new to Polyglot and SolarEdge. just added the node server, created the "api_key" <xxxxxxxxxxxxxxxxxxxxxxx> perameter, restarted node server & it did discover 1x controller, 1x site & 1x inverter, however the logs via polyglot show "2020-03-11 19:01:33,574 [NodeServer] [ERROR] Model SE10000H-US000BNU4 is not yet supported: when I view controller node in isy, field <NodeServer Online> = True, node Site most fields are blank except for <Production> which shows aproximately "6202.893w" Will you be adding support for my Model inverter??
