mike_ws
  1. mike_ws posted a topic in eisy
    When I click on the Upgrade BIOS button, a dialog pops up saying "BIOS upgrade requires connecting your eisy to an HDMI monitor and booting into the 2nd partition". Has anyone gone through this process successfully? Just thought I'd ask before going through the effort of moving things around to connect a monitor and keyboard.
  2. I'm attempting to install the ST-Sonos NS after updating to PG3x version 3.1.17 on my Eisy. I'm seeing the following error message in the NS log: 2023-01-03 17:44:21 error: POLY: uncaughtException: spawn node ENOENT Error: spawn node ENOENT at ChildProcess._handle.onexit (node:internal/child_process:283:19) at onErrorNT (node:internal/child_process:476:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) Log files attached. ST-Sonos_1-3-2023_60617-PM.zip
  3. FWIW - I'm seeing the very same error when I attempt to install a trial version of the ST-Sonos node server. Following to see if someone comes up with a fix.
  4. Anyone else having trouble creating a Polyglot v3 backup on an Eisy? I'm never prompted to save a file when I click on the Download Backup button. Works fine on my Polisy. Both have 5.5.0 installed.
  5. Using the (Re)Install button was successful! The "Ecobee Controller" showed up in the Admin Console and the notice with the PIN showed up in the Polyglot dashboard. Thanks to the both of you for the help!
  6. Yes, it's PG3. (That's the only PG listed with the Eisy, the menu option for PG2 has been removed.) I've uninstalled the Ecobee NS and reinstalled, no change in behavior.
  7. I stopped it, waited about 12 minutes, and then restarted...no change, no PIN. Still seeing the same error in the Polyglot log file when I attempt to view the Ecobee log file.
  8. I've checked the NS config tab, no PIN displayed that I can see.
  9. Rookie/beginner question - I've installed Ecobee as my first node server on an Eisy. The first step of the initial setup section of the README indicates "on first start up you will be given a PIN". How is the PIN given? My first guess was that the PIN would be shown in the Ecobee NS log. The "Real-time Ecobee log file" section, though, is empty. The Polyglot log file contains the following lines that may be related to the empty Ecobee log file: 12/28/2022, 09:02:27 [pg3] info: Starting log stream for pg3frontend_esyBs :: /var/polyglot/pg3/ns/0021b9026040_1/logs/debug.log 12/28/2022, 09:02:27 [pg3] error: unhandledRejection REPORT THIS!: [object Promise], reason: Error: ENOENT: no such file or directory, access '/var/polyglot/pg3/ns/0021b9026040_1/logs/debug.log' As I indicated above, this is my first attempt at using a node server...do I need to configure/setup something in Eisy/Polyglot? Thanks
