keepersg
  1. Thanks Bill, I will give this a try
  2. I have an open ticket on this but no solution as yet. Any help from forum members appreciated.
  3. Upgrading to 6.0. I had a hiccup when the Eisy wouldn't connect with the admin console, portal, or mobile app. Solved by reconnecting it to wifi. Unfortunately, the plugins are now disconnected in PG3 and not providing any data to the Eisy. I'll let things sit overnight but obviously this won't work. Paticularly disturbing is not having any of the Elk data. Other plugins are also not providing data and show disconnected in PG3. I've rebooted, restarted the plugins etc to no avail. So I tried one more thing, reinstalling all of the plugins. They connected and the data is now coming in so problem solved. Not exactly a seamless upgrade but it appears to be all working now.
  4. I am unable to add my Schlage Connect Smart Deadbolt Model BE469ZP to my Eisy. The problem is exactly as that described in the thread in 2023. All I get is a single Entry node with none of the functionality (Lock/Unlock, Status, Battery) that is supposed to appear. I've read through the 2023 thread and tried all of the suggestions there noting that the problems was supposed to be fixed by an Eisy update. I don't see f/u after that. I've attempted to add from the Mobile app as well as the Admin console, resetting the lock for each attempt and removing the failed node prior to each attempt. There is a successfully enrolled Z wave switch a couple of feet away from the lock. No luck. Any help appreciated. I'll open a ticket if there's not a current procedure for fixing this. Thanks.
  5. That did it! Thank you very much for your efforts to solve this. Much appreciated. Among, other things, I use the solar radiation value to determine whether the green house lights stay on during the day. Particularly important in the early part of the growing season here in the Northwest.
  6. I haven't ever had to reboot the isy994. eisy has been running for months without needing a reboot. Java and windows access is still the same old pain....
  7. Here's the java log during admin console start up. Looks like the admin console is regarding that node entry as invalid: Java Web Start 11.431.2.10 Using JRE version 1.8.0_431-b10 Java HotSpot(TM) 64-Bit Server VM JRE expiration date: 2/15/25 12:00 AM console.user.home = C:\Users\keepe ---------------------------------------------------- 😄 clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- http://192.168.1.117:8080/WEB/iox.jar http://192.168.1.117:8080/WEB/ce.jar http://192.168.1.117:8080/WEB/bc.jar http://192.168.1.117:8080/WEB/chart.jar U7[10].[18]addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db849ae9_1" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="WINDDIR" EDITOR="I_DEGREES"/> <st ID="GV6" EDITOR="I_DEGREES"/> <st ID="SPEED" EDITOR="I_SPEED"/> <st ID="GV7" EDITOR="I_SPEED"/> <st ID="GUST" EDITOR="I_SPEED"/> <st ID="GV5" EDITOR="I_SPEED"/> <st ID="RAINRT" EDITOR="I_RATE"/> <st ID="GV16" EDITOR="I_RAIN"/> <st ID="GV1" EDITOR="I_RAIN"/> <st ID="GV2" EDITOR="I_RAIN"/> <st ID="GV3" EDITOR="I_RAIN"/> <st ID="GV4" EDITOR="I_RAIN"/> <st ID="GV14" EDITOR="I_COUNT"/> <st ID="GV11" EDITOR="I_BATTERY"/> <st ID="SOLRAD" EDITOR="I_RADIATION"/> <st ID="UV" EDITOR="I_UV"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="GV9" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> <st ID="GV15" EDITOR="I_COUNT"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [PM25] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) Z-Wave event: control=[_25] action=[1.3] -- Extended Info -- <eventInfo> <zwave CBP="false" CONNECTED="true" RELAXDELAY="0" INTERVIEWTIMEOUT="0" SECUREINC="2" HOMEID="3883420666" NODEID="1" RELAXDELAYDEFAULT="15"/> </eventInfo> -- Z-Wave event: control=[_25] action=[7.1] -- Extended Info -- <eventInfo> <options> <files ZMATTER="true"/> <dongle ZMATTER="true" ZWAVEOTHER="false"/> </options> </eventInfo> -- Z-Wave Backup Options: - zmatterFile= true - 500SeriesFile=false - zmatter connected=true - other connected=false Zigbee event: control=[_27] action=[1.3] -- Extended Info -- <eventInfo> <zigbee CHANNEL="26" CONNECTED="true" RELAXDELAY="0" INTERVIEWTIMEOUT="0" RELAXDELAYDEFAULT="1" CHANNELDEFAULT="26"/> </eventInfo> --
  8. Tried this, including a reboot iteration. Unfortunately, I had the same result.
  9. The plugin reads many values from Ambient and correctly lists them in PG3. The plugin log shows no errors in doing this. UDI mobile shows all of these values correctly but the admin console doesn't. The indoor node has correct values but the main node shows the values from the last node accessed. It will show the values from the indoor node or from any node. Below is a screen shot of the main node right after I accessed the Flume sensor node. The eisy log shows no errors and periodic reporting of the different values from the plugin. I agree this is some issue with the admin console and will open a ticket on this.
  10. That was the problem and removing the & enabled the plugin to get the data from Ambient Weather. However, I have a new issue. The plugins data shows up correctly in UDI mobile but not in the administrative console. I'm seeing only a few values in these three nodes: And the data displayed are not current or matching what is shown in Polyglot or UDI mobile. I have deleted and reinstalled the nodeserver, restarted the admin console, cleared the java cache with no change in the results. Appreciate any help.
  11. Very helpful. Thank you, I'll fix that tonight.
  12. I've installed the plugin, retrieved an API from ambientweather.net and only one node is created with my weather station's name. I've done this multiple times without success. The Ambient Weather plugin on Homeseer works flawlessly. Simply can't get it to work. Log on startup is attached. Any help appreciated AmbientWeather_1-8-2025_81244_PM.zip
  13. @Geddy....Just a restore from the data in IoX to the device. I think it was likely just the connection to the PLM.
  14. After much delay, I have finally migrated my system to my eisy. It went reasonably well, the only hiccup being that I had to restore the settings on many of my devices after the migration to access them I'm not sure why that was...my Insteon devices cover the entire product generation line (still a couple of originals in service) to i3. No rhyme or reason I could discern on which required a restore. It's now up and running perfectly except waiting for the Ambient Weather plug in to populate. I have to say, pulling the ISY994 out of my automation cabinet was surprisingly difficult emotionally...long a faithful service by that little machine. I'll keep it as a backup in case things go south. Many thanks to UDI (Michael especially) for all the initial help with getting the eisy going and for so many years of such excellent support.
  15. Interesting. I have multiple devices that have had successful simultaneous (shared) connections on port 2101 to the Elk from the ISY994, HS3, HS4, and the Automation Bridge. It is true that running Elk RP will block those connections. It connects securely on port 2610 and apparently requires dedicated access. So, I disconnected all of the devices that have had access through port 2101 to the Elk M1G. The Elk NS then connected and correctly created the nodes for my system. I then reconnected the ISY994, HS3, and HS4 successfully and all the devices and the Elk NS are able to share port 2101 successfully. M1 Firmware 5.3.10 MXEP firmware 2.0.44. non-secure access is enabled. It would be a serious limitation if the Elk M1G couldn't connect to multiple devices since that would prohibit the utilizing it for home automation if you had it connected to an external service for monitoring.
