richtimpa
Everything posted by richtimpa
  1. I tried that multiple times under Alexa plus and it didn’t work. Why reverted back to standard everything was fine.. I’m glad it worked for you.
  2. As I’m sure some people have seen on the thread about the Alexis skill for ISY and some issues people are having, I had a long conversation with Amazon and they confirmed that the Alexa+ does not play well with some of the third-party skills. Especially with home automation. I had a few lights that were not responding to Alexa commands and also I have the Harmony hub app and that stopped working as well After talking with them, I had customer service. Take me off Alexa.+ and bring it back to the regular Alexa. As soon as that happened, everything started working normally again. If anyone looks at the other thread, I copied what they said in their text and posted it there.
  3. I have some new information after talking to Amazon customer support. They said there are many issues using Alexa plus with the ISY. The best way to recover is to go back to standard and you have to get on customer service to ask them to remove Alexa, plus. See attached pictures
  4. I’m also getting this as well. I’m not sure how to address it and whether it’s a Alexa problem or a portal problem. I didn’t notice while using the Alexa app. If I clicked on that particular device that’s giving me an issue at the top. It says that it has a server error.
  5. Well, I’ve had all the connections checked and all the grounds checked to make sure that they are tight and I’m still seeing communication issues. One of the things I’m considering is to bring in an electrician to put in some sort of whole house noise filter at the main panel. I figured I’d ask out here if anyone has had this done and wound up with success in clearing up communication issues with Insteon
  6. Bigdvette I did in fact replace my POM with a brand new one. I did move the plm to different outlets to see if that effected coms and it seems it may a bit. my real question is since Tesla came out, do you see that your communication and queries are better or the same. I will tell you that all of my switches, including my PLM or dual.Band. I feel I am kind of willing to live with a bit of flickering that I get currently but it’s extremely important to make sure that my communication between EISY and my switches are as good as possible. any insight or comments to this would be appreciated
  7. Interesting info. Since my flicker is a min, I’m more concerned about the comm errors. I took the liberty of using a long extension cord to plug it in to a further AC plug near the other side of the house to see if that helped to resolve some of the common errors. It did seem to make an effect and I’m still judging it. It would be good, however to still figure out why when I shut down the power walls and disconnect them from the house all of my other problems go away. Do you have any opinions on this?
  8. About 20 mins
  9. @bigDvette I kind of agree and I look forward to hearing what Tesla says when they finally come out to investigate. While the flickering is a little annoying INSTEON, my bigger problem, I believe is communication errors through EISY. I haven’t tried moving my PLM around using extension cords to see if it changes if I put it on a different socket. I truly wish I could address the errors and communication inquiries, which is causing me more concern than the flickering. Any suggestions you or anyone else has to increase? Reliability of communications would be greatly appreciated.
  10. Cooltoys first of all, let me thank you for the large write up and you went over a lot of information. My question is regarding Insteon communications. Putting in the whole house filter and surge protector help with communicationsinsteon? Did you find that communication and queries improved?
  11. Many have seem issues after installing Tesla powerwall 3. Was trying to figure out how to get these issues go away. I suggest you look at this link and see if you could add any additional information regarding this and share it with the rest of us. https://forum.universal-devices.com/topic/44344-issues-after-installing-tesla-powerwall-3/
  12. Typically, when using EISY and I’m replacing an Insta device, I could just do a replacement and not have to reprogram everything. I would like to replace my 6 key keypad with the four key I three. Only using four of the buttons on the six key keypad. One of the things I love about EISY is that is easy to replace a switch without having to go back in and change all the programs. while I know it doesn’t look like a direct replacement. Is there any way to do this easily using EISY?
  13. What issues did you have and what did you think it helped with?
  14. Fwiw someone said these don’t flicker https://inovelli.com/products/z-wave-800-red-series-smart-2-1-on-off-dimmer-switch?variant=41767605534885 again I’ll ask what could help comm issues
  15. While I definitely understand that the flickering is a bit annoying or pulsing. In my case, the secondary and more important issue is I find that with the power wall active, I see a lot more communication issues with.Eisy. ideally, I would like to figure out how to eliminate the communication issues that the power wall seems to be causing. I have installed two of the XPNR filters.(one on each leg.) within the power wall to see if that helped. i’m not 100% sure but it may have helped a little bit. Regardless, I still have some communication issues, and I even temporarily tried moving the PLM to another socket to see if that helped. I only tried moving it to one other socket. It didn’t seem to make a difference. I even tried replacing my old PLM with a brand new one to see if that helped. since I only have some pulsing on a few of the lights, I definitely consider the Insteon communication issue a much bigger problem that I would like to address. does anyone have any ideas on what could help?
  16. We’ll still working on this problem anyone have any updates?
  17. Well, I am glad to hear that that brand of switch doesn’t blink. My only problem with moving over to them is the fact that if I use something like Z wave, my. Eisy would require extensive reprogramming on the replacement in on switches since eisy provides easy replacement of Insteon without reprogramming. I currently do not want to convert off of. Eisy at the present time. The other main issue is that why saw a small improvement in communication errors being reduced perhaps while putting in. A Xpnr on each of the two power walls, I still see issues with communication on queries. I would really love to try to resolve the communication issue and I’ve been looking for a solution on that.
  18. So any other updates from anyone in resolving these issues with powerwall 3?
  19. It’s under this I changed it to 2.5 as it seemed it was worse when set to 1.5 the Pics are from the Tesla manual so ignore the pics say 50hz fyi
  20. So I downloaded the Tesla one app for installers and when the installer was out here, I took a picture of the tag inside the primary power wall. as I mentioned before he put 2XPNR filters on each of the power walls leg one and leg two. And we reduced the back up offset frequency to 1.5. It seemed like communication queries got a little worse so I logged in myself today and changed it back to an offset of 2.5 to see if that helps. I will advise if I think communication is better now, but the flickering is still there.
  21. It’s good to know that your flicker went away with those switches. Also, I imagine you won’t have the communication issues that I’m having with Insta on queries. I’ve been looking at inovelli Zwave also. When replace an Insta switch with one of those switches, do you have to rewrite all the programs or can you do a replace like you do when an Insteon switch goes bad to replace it with a new one or do you have to search and replace on all your programs.
  22. Just another update on trying to fix communication issues and the blink every 1-2 mins on some dimmers with Insteon and the power wall 3. I had the installer put in 2X 10 Xpnr filters, one on each leg of the power walls. (I have 2 pw3s) They also installed a doughnut wrapped 2 times surround the outgoing power from the power walls. I don’t think there is any Change in communication but I will continue to test. Also, some lights blinking every minute and a half or so that is still happening. I also had them change the backup frequency shift to a maximum of 1.5 Hz from what it was before. don’t know exactly what to try next to improve communication as I feel that is the more serious problem anyone else had any more progress on this?
  23. Still waiting for the iOS upgrade and just fyi
  24. Interesting. I also see that using AC on the computer it seems that some queries fail and if tried again, it works so definitely some level of noise from the powerwalls. Installer is coming back out to even try adding more ferrite cores from Tesla on the lines. I can share with you that the best ferrite cores to use are type 31. Others may not work as well at suppressing noise on the line and you may want to try those. I’ll keep you posted on what happens after installer call on Monday
