bocarob
  1. bocarob changed their profile photo
  2. Omg i am sorry blind got it .... all good now........
  3. First thank you for getting back: I can not find my profile you mean my account? and in the email space i put the amazon login id ?
  4. Yes after I initially installed the skill and allowed Amazon to have the right to have access I went back and added the device and then to the discovery and nothing came up no errors no nothing then I remove the skill logged out and logged back in wait a little time reload skill went through the same procedure added a new device initiated discovery and it still was not found thank you for your response
  5. I have one device declared and it does not find it... For the fun of it i added 1 more still does not find it ......very frustrating as i see no errors
  6. I have installed google home link working just fine but every time I try to install the new echo skill ( new echo account never linked before this) skill asked to link to my echo account but never asked for my isy portal information I did a discover no devices have one device created under echo......Tried uninstalling and reinstalling many times .......please advise Google home working just fine.... Thank you Robert
  7. Hello all I see in the portal we can down load our table but I donot see away to import them say from google to echo and back would be nice.... Thank you Regards
  8. bocarob replied to MarioLanning's topic in Amazon Echo
    Which model t stat do you have ? Thanks Robert
  9. Mine is going a bit wacky no response can not find command had to reboot thought it was internet connection but no . it has not been reliable for a few days on and off.. Just got back Wanted wish you Barry a very Happy holidays and a huge thank you giving the best xmas gift this year your hard work and conviction to this project ....... Many Thanks and Happy New Year !
  10. I am running 1.0.7 it seems like it gets confused i i give it a command it says ok but nothing happens but then if i give the same command it works just fine it happens alot not the harmony part as i only have one hub on harmony app running the other are isy only but if i take out the 3 other hubs it works just fine
  11. Barry and Blueman2: ​Barry I did get the new pi 2 and manage to get all the bridges up and working great harmnoy rest is also working as i can make calls from the web and I get info and action back but when i uses 4.0.4 I get the same problem as above it force closes and alexa see the device but can not act upon it here is my config: [system] My Browser = C:\Program Files (x86)\Google\Chrome\application\chrome.exe My Echo = echo.amazon.com/#settings/connected-home Debug = All ' debug options are any or all of 'All ISY DVC HRM SCK CSTM' Emulators = 4, 10 ' first number is the maximum number of emulators to look for, the second the number of seconds to look. [uDI ISY994] ISY userid = ******** ISY Password = p***** [Emulators] ' This is an optional section. It's presence precludes a uPnP search 192.168.1.87:8081=Bridge1 192.168.1.87:8082=Bridge2 192.168.1.87:8083=Bridge3 192.168.1.87:8084=Bridge4 [Harmony Hub] Emulator = 192.168.1.87:8085 Antonyms = Up/Down, Left/Right, On/Off, Forward/Backward, ToStart/ToEnd, BackToTick/ForwardToTick, FastForward/Rewind, Play/Pause, 16:9/4:3 [Custom Endpoints] [Device Types] Controller = 0 Dimmer = 1 Switch = 2 Network = 3 Irrigation = 4 Climate = 5 Pool = 6 Sensors = 7 Energy = 9 Shades = 14 Access = 15 Security = 16 X10 = 113 ' ' If you have other types of Zwave devices that have an On/off operation they may be added here [Zwave Categories] id=0, name=Uninitialized id=101, name=Unknown id=102, name=Alarm id=103, name=AV Control Point id=104, name=Binary Sensor id=105, name=Class A Motor Control id=106, name=Class B Motor Control id=107, name=Class C Motor Control id=108, name=Controller id=109, name=Dimmer Switch, dim=true id=110, name=Display id=111, name=Door Lock id=112, name=Doorbell id=113, name=Entry Control id=114, name=Gateway id=115, name=Installer Tool id=116, name=Motor Multiposition id=117, name=Climate Sensor id=118, name=Multilevel Sensor id=119, name=Multilevel Switch id=120, name=On/Off Power Strip id=121, name=On/Off Power Switch id=122, name=On/Off Scene Switch id=123, name=Open/Close Valve id=124, name=PC Controller id=125, name=Remote id=126, name=Remote Control id=127, name=AV Remote Control id=128, name=Simple Remote Control id=129, name=Repeater id=130, name=Residential HRV id=131, name=Satellite Receiver id=132, name=Satellite Receiver id=133, name=Scene Controller id=134, name=Scene Switch id=135, name=Security Panel id=136, name=Set-Top Box id=137, name=Siren id=138, name=Smoke Alarm id=139, name=Subsystem Controller id=140, name=Thermostat id=141, name=Toggle id=142, name=Television id=143, name=Energy Meter id=144, name=Pulse Meter id=145, name=Water Meter id=146, name=Gas Meter id=147, name=Binary Switch id=148, name=Binary Alarm id=149, name=Aux Alarm id=150, name=CO2 Alarm id=151, name=CO Alarm id=152, name=Freeze Alarm id=153, name=Glass Break Alarm id=154, name=Heat Alarm id=155, name=Motion Sensor id=156, name=Smoke Alarm id=157, name=Tamper Alarm id=158, name=Tilt Alarm id=159, name=Water Alarm id=160, name=Door/Window Alarm id=161, name=Test Alarm id=162, name=Low Battery Alarm id=163, name=CO End Of Life Alarm id=164, name=Malfunction Alarm id=165, name=Heartbeat id=166, name=Overheat Alarm id=167, name=Rapid Temp Rise Alarm id=168, name=Underheat Alarm id=169, name=Leak Detected Alarm id=170, name=Level Drop Alarm id=171, name=Replace Filter Alarm id=172, name=Intrusion Alarm id=173, name=Tamper Code Alarm id=174, name=Hardware Failure Alarm id=175, name=Software Failure Alarm id=176, name=Contact Police Alarm id=177, name=Contact Fire Alarm id=178, name=Contact Medical Alarm id=179, name=Wakeup Alarm id=180, name=Timer id=181, name=Power Management id=182, name=Appliance id=183, name=Home Health id=184, name=Barrier log file: [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v0.4.10) starting setup.... [main] INFO com.bwssystems.HABridge.devicemanagmeent.DeviceResource - HABridge device management service started.... [Thread-0] INFO spark.webserver.SparkServer - == Spark has ignited ... [Thread-0] INFO spark.webserver.SparkServer - >> Listening on 0.0.0.0:8081 2015-11-03 13:25:52.580:INFO:oejs.Server:Thread-0: jetty-9.0.z-SNAPSHOT 2015-11-03 13:25:53.428:INFO:oejs.ServerConnector:Thread-0: Started ServerConnector@188115a{HTTP/1.1}{0.0.0.0:8081} [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started.... [main] INFO com.bwssystems.HABridge.upnp.UpnpSettingsResource - Hue description service started.... [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener starting.... [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener running and ready.... [qtp15447091-17] ERROR com.bwssystems.HABridge.hue.HueMulator - Error on calling url to change device state: http://192.168.1.87:8085/harmony/start [qtp15447091-21] [qtp15447091-21] ERROR com.bwssystems.HABridge.hue.HueMulator - Error on calling url to change device state: http://192.168.1.87:8085/harmony/start [qtp15447091-21] [qtp15447091-12] ERROR com.bwssystems.HABridge.hue.HueMulator - Error on calling url to change device state: http://192.168.1.87:8085/harmony/start [qtp15447091-21] [qtp15447091-21] ERROR com.bwssystems.HABridge.hue.HueMulator - Error on calling url to change device state: http://192.168.1.87:8085/harmony/start [qtp15447091-21] I also can also run test as the program closes with no error Many Thanks Robert
  12. The Fifth Element - Aziz Light! Just for the fun of it........
  13. Come on guys is no one using this plugin.......many thanks in advance
  14. Hi can some one explain how to program event ghost to run a program I assume that send manual command it the ticket but what goes where ....control action etc many thanks .. Robert
  15. I did not reprogram anything I have attached a log then i tried a restore for the fun of it to see if that help and got a comm error so the restore failed but the device will not stay in the off mode ever this is common to all 4 of my older type motions the new type seem just fine. log attached it is not a zip file but text file ISY-Events-Log.v3.2.6__Wed 2012.05.09 09.18.55 AM.zip
