proj964
  1. pkg add tells me to use pkg install???
  2. Never mind. I can't read. URL entered incorrectly. Sorry for the forum noise. Jon
  3. Thanks for getting back to me. In other events, yes. Not this time. See attachment. Jon eisyui logon error jun 6 2025.pdf
  4. Hi, It's installed and running. However, the edge browser dies on the https://eisy with the following and there are no ignore options: eisy.home.local uses encryption to protect your information. When Microsoft Edge tried to connect to eisy.home.local this time, the website sent back unusual and incorrect credentials. This may happen when an attacker is trying to pretend to be eisy.home.local, or a Wi-Fi sign-in screen has interrupted the connection. Your information is still secure because Microsoft Edge stopped the connection before any data was exchanged. You can't visit eisy.home.local right now because the website uses HSTS. Network errors and attacks are usually temporary, so this page will probably work later.
  5. Part of it is in the title, but, you're right I wasn't specific. And I naively thought that it didn't matter with matter devices who made it or when or what it was as long as it was matter... Linkind, Smart Plug, B-Type, 2523-311-2219, date code: 2311.
  6. Hi, I get 5.9.1_18 updated on apr 21 (thanks). tried to add the device again. same error.
  7. hmmm, somewhat confused. when i go to Releases , 5.9.1 is the latest that I see. thanks, jon
  8. Hi, I am using Android.
  9. i have tried several times and keep getting the same error (yes the definition of insanity). "Could not add Matter Device Bluetooth Unsubscribed. 500" which, oddly enough, means nothing to me the user!
  10. @Michel Kohanim I don't think anyone intended to ding your helmet. We are all just "anxious" and "waiting". Aeotec has a Smart Home Hub that is: Certified to work with Google, Alexa, SmartThings, Matter, Wi-Fi, Z-Wave Plus, and ZigBee protocols. We would just like to see Matter in UD's eISY (as it also supports Insteon and we like it alot). Keep up the good work! Jon
  11. I don't have a "migrate button" on the configuration page and none of the z-wave devices work/communicate. all except for two show "placeholder". none of them communicate. hope this gets fixed soon.
  12. whoops, my bad. I didn't really follow the instructions, per se, because of "Note: Shifting Primary Control is only available if there is no SIS in the Z-Wave network." The 994 is a SIS so I did "Add a Z-Wave Device" not "Shift Primary to another Controller". Do you still want me to open a ticket? Sorry for the slight confusion.
  13. Hi Michel, I have tried that, just did it again, it just sits there with an open dialog box, one for each, and does nothing. Jon
  14. I have tried for some time to find a combination between ISY admin consoles and Si Z-Wave PC Controller to shift the Z-Wave SIS function from my old ISY994i to my shiny blue Polisy. But, alas, nothing works for me. Any thoughts?
