proj964
Everything posted by proj964
  1. pkg add tells me to use pkg install???
  2. Never mind. I can't read. URL entered incorrectly. Sorry for the forum noise. Jon
  3. Thanks for getting back to me. In other events, yes. Not this time. See attachment. Jon eisyui logon error jun 6 2025.pdf
  4. Hi, It's installed and running. However, the edge browser dies on the https://eisy with the following and there are no ignore options: eisy.home.local uses encryption to protect your information. When Microsoft Edge tried to connect to eisy.home.local this time, the website sent back unusual and incorrect credentials. This may happen when an attacker is trying to pretend to be eisy.home.local, or a Wi-Fi sign-in screen has interrupted the connection. Your information is still secure because Microsoft Edge stopped the connection before any data was exchanged. You can't visit eisy.home.local right now because the website uses HSTS. Network errors and attacks are usually temporary, so this page will probably work later.
  5. Part of it is in the title, but, you're right I wasn't specific. And I naively thought that it didn't matter with matter devices who made it or when or what it was as long as it was matter... Linkind, Smart Plug, B-Type, 2523-311-2219, date code: 2311.
  6. Hi, I get 5.9.1_18 updated on apr 21 (thanks). tried to add the device again. same error.
  7. hmmm, somewhat confused. when i go to Releases , 5.9.1 is the latest that I see. thanks, jon
  8. Hi, I am using Android.
  9. i have tried several times and keep getting the same error (yes the definition of insanity). "Could not add Matter Device Bluetooth Unsubscribed. 500" which, oddly enough, means nothing to me the user!
  10. @Michel Kohanim I don't think anyone intended to ding your helmet. We are all just "anxious" and "waiting". Aeotec has a Smart Home Hub that is: Certified to work with Google, Alexa, SmartThings, Matter, Wi-Fi, Z-Wave Plus, and ZigBee protocols. We would just like to see Matter in UD's eISY (as it also supports Insteon and we like it alot). Keep up the good work! Jon
  11. I don't have a "migrate button" on the configuration page and none of the z-wave devices work/communicate. all except for two show "placeholder". none of them communicate. hope this gets fixed soon.
  12. whoops, my bad. I didn't really follow the instructions, per se, because of "Note: Shifting Primary Control is only available if there is no SIS in the Z-Wave network." The 994 is a SIS so I did "Add a Z-Wave Device" not "Shift Primary to another Controller". Do you still want me to open a ticket? Sorry for the slight confusion.
  13. Hi Michel, I have tried that, just did it again, it just sits there with an open dialog box, one for each, and does nothing. Jon
  14. I have tried for some time to find a combination between ISY admin consoles and Si Z-Wave PC Controller to shift the Z-Wave SIS function from my old ISY994i to my shiny blue Polisy. But, alas, nothing works for me. Any thoughts?
  15. When using the device>wakeup interval>write changes with the device set manually awake, nothing appears to happen. The event viewer only says forced writes followed by nothing. The device continues to wake every 4 minutes. Several intervals chosen from 5 minutes to 1 hour; makes no difference; still is on an every four minutes cycle. The device page has a "set configuration" but no read configuration; seems odd. Also, how does one issue a Wake Up Interval Capabilities Report Command and get a result? Thanks, Jon ISY v5.2.0 Z-Wave v6.82.01
  16. Security - Back Timer
  17. IndyMike, Thanks for the explanation. I am not sure I understand this as the "Security - Front Lights" is an identical set of programs except it turns on/off a different Togglelinc. In all other ways, the "front" and "back" program sets are identical and the front never fails to operate as expected. Oh, and both front and back worked just fine, as is, when the motion sensor was an Insteon motion sensor (2844-222 configured as a 2842-222).
  18. Will remove and re-add per recommendation and report back. Update: I removed and added back earlier today with the status check for "off". Did "Update" and "Save Changes". Now it says "100%" and "responding" -- not what I put in when I added the switch back to the program.
  19. It was added to the ISY994i by address. It is and shows as a 2466S ToggleLinc
  20. I will set it back to "off" which is what I put there in the first place. But note the the bottom panel show "responding" yet again. Isn't it possible that there is a bug somewhere in the isy994i?
  21. Hi, I recreated the program and disabled the old one. However, this did not help out. I have included the latest screen shot of the recreated program. Now the status line is even more confusing; although when I re-entered it, the condition test was "off". I should point out that when the motion detector was an insteon device, this set of programs worked just fine. Changing to zwave resulted in the problem of one program running correctly and one not.
  22. Thanks. I will try disable and recreate.
  23. Thanks for helping with this problem. Device is Insteon ToggleLinc switch. It turns on/off just fine from the admin console. Query also works just fine; see attached file screenshot. The device status is there so that if the switch has been turned on manually, the program doesn't cause it to be turned back off.
  24. Thanks for the idea... Yes I have saved the changes before...doesn't appear to make a difference.
