ahagie
  1. You Cant do Insteon, Zigbee AND ZeeWave on the ISY at he same timeY
  2. I literally just want to be able to add Zigbe devices to my ISY (I already have Insteon and Zigbee installed) . Can I do this by added the ST Hub to my isy? or vise versa?
  3. Different user interfaces and apps, plus I can use insteon with Isy, not with ST.
  4. Ugh I was hitting the Close button instead of the Clear Button lol...Here is what I see, but it appears no info from the ST Hub
  5. Ive read the Forum, and it appears as though these are the simple steps, but I canget a reply from either sde. I have my ST Hub and my ISY 6 inches apart at best I put the ISY into Learn Mode I goto the ST interface and addd device, then click auto Detect. What am I missing? I know the ISY Can see ZeeeWave items becaseu I adde my August at ne time beffore Moved it to the ST. I cant run the Diag at the same time as adding the device as it wont let me...ideas?
  6. OK so, I've gotten theMagicHome LED WiFi Controller to: Turn On Turn Off Turn Blue Turn Red Turn White Tur Cyan But I cant find the commands anywhere for anything else? Dim. Mode, Speed, Fade? Here are the commands in case anyone would like them, also it Must be in Binary Mode, Port 5577 (See example of ON command) Any help would be appreciated:
