esloyer
  1. I also started experiencing issues 7/17 early in the morning. Can't seem to figure out if it's a Portal issue or a DNS issue.
  2. Looks like that did the trick, thanks!
  3. Is anyone else having an issue with the Default mail server feature in the ISY? I'm on V5.2 now and I can't seem to get the mail server to work.
  4. I have been searching online and the forums but have not found a solution to this yet. I have an outdoor hot tub with 6 different pumps (all use the same return line) and I would like to measure the temperature of the return water with the ISY. Depending on the return temp and the outdoor temperature, I want to be able to adjust the temperature of the hot tub. I know I can use PolyGlot and the different weather integrations to get the outdoor temperature, but I am not sure how to measure the return line temp. It looks like Insteon used to have a wireless thermostat with an external probe, but that is no longer for sale. Any ideas on this?
  5. Agreed, the cert is what holds all of the internal comms together.
  6. I can't get the Portal to work, Google Home connection or PolyGlot sign in now because of this. Can this be fixed QUICKLY?
