NJBILLT
Everything posted by NJBILLT
  1. NJBILLT replied to NJBILLT's topic in ISY994
    Same as Homeseer then, and yes I do use strong UN/PW and yes, attempts do show up in the log once in a while. But Homeseer also has IP hack blocking. I've always felt secure with it, even seeing attempts, I know they're just trying a brute force attack by the UN/PW combos they try. Usually from Chinese or Russian IPs by the way. Enable IP Hack Blocking: YesNo Time to block triggered IP addresses (minutes): Invalid access 'hits' before block imposed: Time between 'hits' to count toward block being imposed (seconds):
  2. Upgrading from Homeseer currently using 2, RCS serial communicating thermostats. Looking for suggestions to replace them. A color touch screen and more elegant appearance then the RSC is desired. Thanks for any ideas. Bill
  3. Amazon delivered the 2413S this morning and I can confirm it is version 2.4 1017. Now all I need is my ISY
  4. NJBILLT replied to NJBILLT's topic in ISY994
    I'll probably subscribe but it's important to note that even with my HS, I only open the port when I go on vacation and might need remote access to check on things. I automate, not remotely control. I rarely touch a light switch at home, why would I want to from afar? Anyway, I see log-in attempts in the HS log all the time from Chinese and Russian IP addresses. They always fail.
  5. NJBILLT replied to NJBILLT's topic in ISY994
    Thanks. I just ordered a ISY994i and a 2413S. I'll decide later about remote access, but I have a free DNS service too from my Asus router, and it's been bulletproof for 3 years, and I use it regularly with my security cams and Homeseer. I do appreciate the help here for this newbie to ISY. Been running Homeseer since version 1.5. I think the transition will be easy. Thanks again.
  6. Thanks. I ordered a ISY994i from UD and a 2413S from Amazon fulfilled by Smarthome. It says it will be version 2.3. I'll report back but should I not accept anything earlier than that? Thanks for your input BTW. This forum is very responsive.
  7. I've had amazing luck with my 2413U. It's been at least 5 years. I did notice on their Amazon listing: "New revision (2.3) addresses issues with hardware longevity"
  8. I actually have access to a spare 2413U from my brother-in-law, so my plan was to keep both running, (if I can adapt to the 2413U) register all the devices on ISY and migrate several events at a time. A cursory look at my HS shows about 25 Insteon devices registered, and about 20 X-10 addresses in use. Of course, and one of the reasons I've been reluctant to switch is I also have dozens of virtual X-10 addresses being used by some of Jon's HS plug-ins. Frankly, his plug-ins give more function to HS than the app itself, but I digress. I'll have to find another way to fill that void. I did use a serial to USB adapter for my RCS RS485 thermostats with HS, and that worked flawlessly for years. They aren't that expensive. I may just roll the dice and try it.
  9. I asked a question yesterday and got a lot of good advice, so I'm hoping someone can offer some expertise here. I am switching from Homeseer 2 with a basic ISY Insteon and X-10 only box. I currently have a 2413U PLM. Is there a way to use that so I don't have to buy the 2413S. I'm thinking a RS232 adapter with FTDI chipset? Any advise appreciated.
  10. NJBILLT replied to NJBILLT's topic in ISY994
    Thank you Paul. Your answer is what I was looking for. I'm not expecting an elegant interface, and it sounds like I'll be able to do at least what I can with HS2 remotely. I plan on switching soon. I'm sure you realize since I didn't upgrade to HS3, I have so much vested in it, it wasn't worth it as I'm not happy with HS anyway. Been using it since version 1.5 BTW. The only thing I may lose is interaction with my RS485 serial thermostats, but they're old tech anyway. Thanks again for the reply. I'm not afraid to open a port on my router for free access once in a while when I'm on vacation or traveling.
  11. NJBILLT replied to NJBILLT's topic in ISY994
    If you don't recommend it then you're as much as saying their server is not secure even with a PW. If it's not secure with a PW then it's not secure at all.
  12. NJBILLT replied to NJBILLT's topic in ISY994
    I am not using HS3 for one, I'm still on HS2 but I find it hard to believe they took away access direct thru my IP. That's what I'm asking about. I don't pay anything to HS nor do I use their bandwidth. I connect directly to my IP
  13. NJBILLT replied to NJBILLT's topic in ISY994
    Thank you. I don't need anything fancy but I want to at least see status and be able to trigger events if I want to
  14. NJBILLT posted a topic in ISY994
    Do I understand that in order to access my home from outside my home I need to pay a fee? Or buy an app? I am currently using Homeseer and wanting to make a change, but this is a deal breaker if true. There's no reason this can't have dynamic web pages served right from the box like HS.
