Everything posted by pinlawr
KPL with 0 size database records in eisy
Looks like the added delays didn't resolve it. My issue came back for one of the devices. I opened a ticket with support.
So far so good with the program delays. Fortunately each device that I had the issue with had no links/scenes/etc attached to them. The SwitchLinqs were just switching the local load, and the KeypadLincs only had the "MAIN" button in use to also switch the local load. Somehow in 6 years I've never actually done anything with the other buttons. I did make sure to copy from a device that also had no links/scenes associated with them. Perhaps after copying the file you could do a restore device in the admin console. The wording says it will reprogram it with the settings in IoX, so maybe that will rewrite the file out as it should be for that device.
getTreeDataPath error w/ eisy-ui 1.0.2
I just updated to v 1.0.2 and when I try to load eisy-ui I get the below error. This was an upgrade from 0.9.0, which loaded fine. Unexpected Application Error!MUI X: The path returned by getTreeDataPath should be unique. The rows with id #47298 and #47298 have the same. Path: ["Master Bath KP C - Color Loop\n47298"].Error: MUI X: The path returned by `getTreeDataPath` should be unique. The rows with id #47298 and #47298 have the same. Path: ["Master Bath KP C - Color Loop\n47298"]. at l (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:109:32974) at qc (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:108:68939) at tL (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:108:69548) at https://eisy.ZZZ.local/assets/App-D57SMzq5.js:110:37 at Object.applyStrategyProcessor (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:99:45114) at UD (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:24:800) at https://eisy.ZZZ.local/assets/App-D57SMzq5.js:104:46170 at Object.setState (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:99:45595) at W (https://eisy.ZZZ.local/assets/App-D57SMzq5.js:104:46145) at https://eisy.ZZZ.local/assets/App-D57SMzq5.js:104:46382I have a scene named "Master Bath KP C - Color Loop" that has ID 47298, and is broken. It has no devices on it and I can't edit/remove/delete/move/rename this scene. It's essentially stuck in my IoX. It's been like this for years and I've never bothered to mess with it as it's just been a very minor visual annoyance before this. I actually have 2 scenes with this exact same issue, but I guess eisy-ui hits the first one and stops.
What a coincidence. I have 4 devices that have multiple changes to their settings depending on time of day. Two SwitchLincs and two KeypadLincs. Depending on time of day things like on level and button backlighting is changed. I noticed that these changes stopped working at some point. I followed the same error message trail and that's when I found the devices in question were either missing it's .REC file, or a .REC file with 0 bytes. The good news I was able to fix it once by copying the .REC of an identical model device to the filename for the device that was missing. This immediately restored the ability to control these parameters (no reboot, admin console still open). Doing it this way I did not have to remove/re-add the device. I just ensured I copied the .REC file from a matching model. On a whim I adjusted the program that changes the parameters to include a 1 second delay in the changes. Previously they were all back to back. The thinking was maybe some IoX process was failing to write these files without a delay. I don't know if it was the underlying cause or not but since then I have not had the issue come back. This system has been running with the same keypad/switchlincs for over 6 years and I don't know exactly when the problem started. I do know that it happened to each of them over time. I assumed the device itself had stopped responding to the parameter changes. Once I found the file issue I figured it could have happened during any number of changes between moving PLMs, from ISY994, to Polisy/IoP, to eISY/IoX, and not counting the handfule of backup/restores that have occured.
Which elements in programs need update?
I found the below info (bolded text by me) in the github docs page on the latest update to Timedata. Can someone clarify which "certain elements" may need to be updated? Timedata is used throughout many of my programs but I don't know what to hunt down and update. I did see the post below where were referencing sunrise/sunset values, but wasn't sure if there were other things to be on the lookout for. Thanks! 3.4.0 28/102/2025 minor code and profile changes to fix a problem with data not showing properly in eisy-ui the changes may require that certain elements in IoX programs be updated.
Button labels Show Command Not Friendly Text
Ah. That fixed it. I did get the notice to sync when I opened the app after the latest update. I did let it do the sync process when prompted. The "additional" sync took care of it. Thanks!
After the latest update on iOS (1.4.3) all the buttons inside a device show the commands (DON) on their label rather than their friendly label such as “On”.
Data Outdated After Vehicle Stops Driving
Sorry for the delay, I forgot to turn on notifications on this thread. Currently everything shows time of last car update was 4/26 14:14. Nothing since then. The car was driven today (4/28) for over an hour, and pretty much all of the data is not current. There are no "stream" type entries in the log file for today's drive. Of note, the commands always seem to work (start/stop charging, honk, etc.) so there is authenticated connectivity to the vehicle. I changed the log level to debug and restarted the plugin. I've DM'd the log from TeslaEVstream. Once the plugin was restarted some of the data updated (mileage, etc.) but not everything, for example it still shows the charger is engaged, but it's not (the vehicle isn't even at home). I also installed TeslaEVpwrSh into a different slot. I just went for a drive. Data in the TeslaEVpwrSh updated some data (but not all), and TeslaEVstream didn't record any changes.
I switched to the new streaming plugin a week or so ago. Since then a lot of my use cases have stopped working correctly due to out of date information, and no way to trigger an update. One of the main use cases for me has been using the plugin to start/stop charging based on the status of the car (rather than just a plain X-X schedule). I also use it to flash lights in the house if I run our goodnight routine and the car is not plugged in and below X% charge. I also have a button on a keypad link that is lit when the charger is connected, and now that light is never correct. Literally right now it shows the charger port latch is engaged. It's not. The car is in the middle of a parking lot. At night, when home and plugged in, it will show disengaged, because it wasn't connected during the drive (obv), and never updated after arriving home and plugging it in. This causes the program that starts charging to not run (it checks the latch state, no need to send the charging start command and wake the car up if it's not plugged in). Once the car gets somewhere and the drive stops, the streaming stops (actually since the mileage and other things are also off, I wonder if it's stopping before the drive ends). A lot of other things stop updating as there is not poll or refresh of the vehicle state after streaming stops. Mileage, temperatures, charging latch state, window/door status, etc. Nothing updates after streaming stops. Currently the car is online (as it's not home and sentry is on) and all the data in the admin panel is out of date. The time of last car update is 10:03:25, but the drive didn't end until 10:07:46. I fully understand the need to move to the new API and reduce calls, but there is still a need to keep the data up to date if the vehicle is online, even if hourly, or with a triggered command. Perhaps when streaming (or vehicle is offline/asleep) don't poll to save calls, but otherwise if the car is online a regular poll schedule seems needed to ensure the data is up to date. I'm happy to provide logs or run tests.
Network Resources Variables
That is URL (not HTML) encoded. You may check your network resource and change the "mode" from URL Encode to Raw Text. Or, if that doesn't help, depending on the code on the server, you should be able to call a URL decode routine. URL decoded output would then be: Source:SunRoom,Temperature:21.6°F,Humidity:70%,BatteryLevel:53% The degree (º) and percent (%) symbols are being encoded.
Support Thread: IoX v5.9.1 (2/10/25)
Polisy updated fine. It took around 33 minutes to complete. I have around 15 plugins running. Wired connectivity.
ModuleNotFoundError lifxlan after move from PG3 to PG3x
Sorry for the late reply, and thanks for the help. I guess I had email notifications off. I ran into this (bitstring problem) a while back when it was first a problem on my PG3 instance and used the above instructions to fix it. Everything worked fine until the move to PG3x. My pip3 list shows "bitstring 3.1.9", but I went ahead and tried the steps you sent just to verify and it made no difference. I'm still getting the same "no module named 'lifxlan'" error, even with pip3 list showing that "lifxlan 1.2.7" is installed. I'll go open a ticket.
Hello! I've been running the LiFX node server on my Polisy for awhile now, migrated from PG2 to PG3 a while ago. Just moved to PG3x. Now when the node server tries to start all I get is the same lines in the log over and over until I stop it. 2023-08-31 16:08:57,295 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.1.0 Starting... 2023-08-31 16:08:57,300 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-08-31 16:08:57,301 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db952cee0_12/lifx-poly.py", line 10, in <module> 2023-08-31 16:08:57,302 MainThread udi_interface ERROR udi_interface:write: import lifxlan 2023-08-31 16:08:57,303 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2023-08-31 16:08:57,303 MainThread udi_interface ERROR udi_interface:write: : 2023-08-31 16:08:57,304 MainThread udi_interface ERROR udi_interface:write: No module named 'lifxlan' 2023-08-31 16:08:58,914 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 I SSH'd in and manually and ran the install.sh script and it re-installed the lifxlan module. I can see "lifxlan 1.2.7" in the list when I "pip3 list". Other potentially relevant version info: PG3x Version 3.2.3 Frontend Version: 3.2.3 IoX Version: 5.6.4 Not sure where to go next to get the node server back up and running. Thanks for any help!
Connect to https resource with self signed cert (hue hub api v2)
Error log was the last attachment. It just says "Net-Resource: Failed connecting to 192.xxxx". Nothing else shows in the log.
My settings are exactly as suggested. In my screenshot you can see that verify is NOT checked. I mentioned that it's set to TLS 1.2 since it's not visible in the screenshot. Resource screenshot shows it's set to a 10,000 timeout. I also mentioned that SNI doesn't make a difference checked or unchecked (and it wouldn't anyway since the cert in question doesn't use SNI). It works from a browser, curl, and postman. I also mentioned it DOES work on a ISY on Polisy, just not on the 994.
I read through the info in this thread (Can you ignore ssl validation in a Network Resource?) and I am basically having the same issue. I've attached my network settings (protocol on both is set to 1.2, since it's not visible in the screenshot). Also attached is the network resource and the simple error message I'm getting back. Toggling SNI changed nothing (which wasn't a surprise since the cert has no SNI entries). The request has to be PUT. I have the self-sign cert from the hub exported, but I don't see any way to import it as trusted, or simply tell the ISY to ignore it. I have a Polisy, but haven't moved to IoP yet. As a test, I exported/imported my network resources into IoP just as they are, and they DID work fine without any errors. Thanks for any help!
404 Error Running Network Resource
I submitted a ticket 9 days ago. I just sent them a follow up.
Not yet. I opened a ticket as suggested but haven’t received any follow up except from the initial submission. Need to go give it a bump.
Done! Thanks!
The error comes up the moment I push the Execute button (so no delay like it's waiting for a timeout). As a test, I adjusted the timeout on one to 5 seconds, the error still popped up the moment I hit execute. All of them work when ran from the console, and all are used daily (or more often) in programs that run both automatically and on demand. Also, all resources are to local devices/servers on my internal network. There are no calls to internet resources. Oh, app version is 0.9.6, just for completeness. ISY is 5.3.4.
Some, but not all, of my network resources return a 404 error when I try to use the Execute option on them from UD Mobile. At first I thought it was only programs that have a dash in the name, but that isn't consistently the problem. When I view the node info the address is correct, etc. I've re-synced UD Mobile and that doesn't help. I also don't see any errors in the event viewer. The network resources DO work when executed via the admin console, or from programs, etc. It's only when trying to use the Execute button from UD Mobile. The full error that pops up is: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="false"><status>404</status><RestResponse> Thanks for any help, Billy
- Reboot Missing?
Reboot Missing?
First, I could be crazy, feel free to tell me I am. Didn't the portal have the option to reboot the ISY? I don't seem to have that option anymore. Having it there was a lot easier than digging behind the device to unplug it, or launching the java client. Thanks, Billy
Device Not Responding This Morning
Disabling, then reenabling the V3 skill fixed this for me (without forgetting and rediscovering all devices).
Thanks, Michel - I sent a support email (and, my apologies, misspelled your name in the email). The request is #19484. I've left it "broken" in case the support team needs any data while it's in this state. I didn't see anything of note in the error logs, but hopefully they're useful.
