Gentstr
  1. Yes, I've flushed the cache after closing all browsers and applications. Then rebooted. I have turned off all antivirus/antispyware/IPS/firewall and still the same problem. I've also tried over https. I have noticed that I can get status updates for a few seconds before a second login prompt appears. After I login again, then pop-up windows and status changes are not reflected. Also, the icons in the nav all have red exclamation points when the login prompt is waiting again, but change back to normal when I press "ok". This second login happens anywhere from 1 to 20 seconds after logging in. The only other change since upgrading was to remove and re-add my v2 thermostats. Yes I meant folders. Good to know you're working on it. You mentioned in the thread http://forum.universal-devices.com/viewtopic.php?t=4115&highlight=led+brightness that "KPL 2D and above" are supported.
  2. ISY-99i running 2.7.13. Flushed cache after upgrade from 2.7.11 and calling from http://myisy/admin. Changes to the navigation don't refresh (i.e. renaming devices, moving devices). I have to close the console and log back in to see the changes. Would be nice to have a force refresh button anyways. As mentioned in another thread, creating a group with the same name as another does not work. I have Upstairs and added Secondary under it just fine. I also have Downstairs and tried to add Secondary under it and it flaked out. The workaround was to create the 2nd Secondary group as another name, and then rename it back to Secondary. I have 2 KPLs v.2D and v.36 that I cannot change the LED brightness. I see that there are only values 0-7, but the product documentation mentions 32 levels. I manually set my v.2D KPL with the C&F presses, but still would nice if it worked. Also if 0 is the default, what do you consider off? I just installed an IOLinc w/ garage sensor last night. Got it to work, but the Wiki instructions don't match up with the same option names anymore. My problem is that the Relay and Sensor icon arrows are pointing the wrong way. Since the icons are arrows by themselves, the name of the device logically is the device. Therefore, the Relay should be pointed to (right arrow) and the Sensor should be pointed away from (left arrow). Can I request a feature be added to the WEB/CLOSE.HTM page to include a link back to the admin page instead of being blank. Due to the navigation refresh problem, I'm closing and have to change the URL manually. A link would be really nice. In general things are running smooth though. Thanks for the hard work!
  3. I have a PLM firmware version 63 that I have used with PowerHome and MisterHouse. I'm now migrating to an ISY, but would like to keep my existing device links. I know about adding devices with the keep existing links option, but should I do anything to the PLM like a factory reset, or leave it as is?
  4. Gentstr replied to me23's topic in ISY994
    I understand that having the ability to receive and/or transmit IR codes isn't supported, but is there at least minimal support of the device? For example, I don't mind manually linking with an IR code, but I would need to have the ISY trigger if certain groups are linked. If there is absolutely no way for the ISY to even perform basic trigger support with the EZUIRT, then I cannot justify the purchase.
