davidn70
  1. Hello, Has anyone been able to successfully proxy their ISY-994 through an apache web server? I have other systems and devices that I have been able to make work. Basically I want to b able to do something like: http://myApacheWebServer/isy and have it proxy to: http://myIsy994 I can get the initial page to display but it does not function correctly. Thanks in advance! David
  2. davidn70 replied to davidn70's topic in ISY994
    Sorry - I meant 3.3.10. I have it pretty much fixed now. I did a "restore devices" and everything seems happy for the most part. A little tweaking and I should be all the way back to 100%. Thanks for your help and patience, David
  3. davidn70 replied to davidn70's topic in ISY994
    I don't think that's the case. I have turned off Avast and the windows firewall - still having issues. I also tried running from my Mac - same issues. I have deleted the scene and re-created it. The wall switch modules all behave as they should. I am unable to get the lamplync dimmers to work in the scene, however. This was working until my dimmer died and smarthome replaced the rev 1.0 with the new rev 4 of the lamplync. Is there anything else I should try? Could the SD card in my isy be corrupted? The first time I tried updating the firmware, it was unsuccessful and took a number of tries to restore my backup. Thanks, David
  4. davidn70 posted a topic in ISY994
    Hello, I am replacing a couple of LampLinc modules in my setup. For some reason I am not able to add them to a scene and have them turn on and off. The ISY-99i pro that I have can turn them on and off. I had not updated my firmware for quite some time and thought it might be due to that. I recently updated to 3.3.1. I was at 2.8.3. The problem persists. Also, anytime I look at a module, it says that the ramp time is 9 minutes. It will not allow me to update it. When I control the modules remotely, it I have to do a fast on and fast off (maybe that's the issue with the scene? I haven't stuck around for 9 minutes to check. The GUI also has major problems refreshing - new scenes do not show up right away. I often have to exit and come back in. Any ideas? My system was rock solid for a long time but I have not had much time to do anything extra with it until one of my lamplinc modules went bad. I have cleared my browser cache and am running Java 1.7.25. Thanks/HELP! David
  5. This is the second time now my ISY has become non-responsive after using the HTTPS REST interface. It appears to still run programs (but further investigation is needed), however, it loses all network connectivity - it will not respond to HTTP/HTTPS or pings. The "solution" is to unplug it from the PLM, wait 15 seconds or so and plug it back in. This last time I let it run for a couple of hours before power-cycling it and it did not recover. Any suggestions? Is there something special I need to do in order to make this more reliable? I am running firmware 2.7.5. Thanks! David
  6. Man you guys are fast. Thank you again! David
  7. Thank you for the quick reply. I'm parsing the XML document returned by /rest/nodes to build a list of devices and scenes that my app can control. Do you know of a reliable way I could detect secondary buttons and filter them out of my list? is searching for .3 and higher a good way to do it or is there something better? Thanks! David
  8. Hello, Using the rest interface, if I go to: (legit IP is in place of IP OF MY ISY) http://IP OF MY ISY/rest/nodes It shows the addresses of KeyPadLincs as (legit data/address is in place of X.X.X) X.X.X.1 X.X.X.3 X.X.X.4 X.X.X.5 X.X.X.6 I get it that .1 is the ON/OFF on the 6 button (i.e. the load). I can't seem to do anything with the other addresses. I would expect the LED to light up if I try to use the REST interface to turn the switch on. I know not to expect any devices to turn on. When I hit the link: (legit IP is in place of IP OF MY ISY) (legit data/address is in place of XX XX XX) http://IP OF MY ISY/rest/nodes/XX XX XX 1/cmd/DON I get an expected response. If I replace the 1 with 3, 4, 5, or 6 I get the following message back: 404 Is this expected behavior? Please enlighten me. Everything else in the app I have written that uses REST works fine except the 4 small buttons on the KeyPadLincs. Thanks in advance! David
  9. Hello, I received 5 of these last night. I have them working with my ISY99 but they show up as Unsupported Device. http://www.smarthome.com/2457D2/LampLin ... Pin/p.aspx I presume that is due to the firmware in the ISY not having the name of the device when it does whatever magic lookup it does. They seem to be working fine. I am pretty happy with them. I was able to use the ISY to put them into scenes etc. Here's my question - is the Unsupported Device message something to worry about? Thanks! David
  10. davidn70 replied to aLf's topic in ISY994
    Glad you got it working. I actually found that port number on a Google support page (don't remember where). I believe there are a couple of different flavors of secure SMTP so they are running different instances on different ports - not 100% sure though....
  11. Thank you very much.
  12. Hi, I have 3 questions about notifications: 1. Where do you set the default SMTP server? I was unable to find that. I had to uncheck Use Default and then enter the information. 2. Is there a way to change the format of the emails that get get sent as notifications? 3. Is there a way to get notifications for every Insteon action other than creating a program and "notify all" in it? Thanks and Happy Thanksgiving! David
  13. davidn70 replied to aLf's topic in ISY994
    I got GMAIL to work yesterday for my ISY as the SMTP server. What worked for me is port 587. Make sure you check Use TLS and have your username and password in there - works like a charm on my end. Happy Thanksgiving! David
  14. davidn70 replied to davidn70's topic in ISY994
    I have combined my replies into one... You can actually run it under Windows - the documentation is VERY sketchy in places. You can download windows software from the site. You need to have a computer running all of the time as it has no autonomous mode. I agree on the picture frame... that would be really coolll
  15. davidn70 posted a topic in ISY994
    I am just curious if anyone else is using a "Tux Droid" with their ISY-99? I got my Tux Droid yesterday. It was very easy to connect it as a network resource as it has a REST interface. I plan on using it for notifications as well as using the text to speech to help my kids memorize things. If anyone else is using one, what are you using it for? http://www.thinkgeek.com/geektoys/rc/9df0/ Regards, David
