gschoffstall
  1. Breakthrough news. Since the module was essentially dead and useless, what's to do? Naturally, take it apart and look at it, right? Eureka! There in the middle of the board lies a sideways radial capacitor glued to another component......with goo leached out and an eaten away lead! Disassemble. Replace the simple 470mfd/35v capacitor. Reassemble. Test. WOW, it's back. Found and linkable. Yay.
  2. It seems that the device partially failed. It actually followed the program until I removed it from the program and tried to re-register it. The only issue was the big red ! . After I removed it from the program, I tried searching by letting it find it with the link mode. When that didn't work, I tried adding it using it's address and choosing the exact description from the list. All I got back was "Cannot determine Insteon Engine" and it refused to link. When it was still working, I guess it retained some semblance of it's link structure, but that got "forgotten" when I removed it. There must be some internal address that got scrambled.
  3. I know, but then there's the other 3500 logins and unique passwords that we are supposed to never divulge, write down, or otherwise compromise, whilst committing them to our photographic memory.
  4. HI Guys, Blindly...I guess. I don't regularly go to the forum. Usually it's to find out why something that worked doesn't any more. When an update is released from now on, I will check before initiating. Thanks for the enlightenment.
  5. After the suggestion that package updates were available, I decided to comply. It took forever, then I couldn't login with my old - admittedly wide open- login of admin/admin. Now it forced me to use my portal login. Seems like extortion to me. Force you to use the portal which requires a fee to maintain. Not that I dislike the portal, I just want to change it back without affecting the portal login.
  6. On an operating system, a device (Insteon #2456S3 ApplianceLinc) spontaneously showed up in the device list with an ! When I removed the device and tried to reinstall it again, it gave me this: "New device errors 1E.F5.37 cannot determine Insteon Engine". I need to stress that the device did still communicate before I removed it. I could turn the device and associated programs on and off in the console. Now it will not even find to link it. Is the module recoverable or not?
  7. Geddy, I got to the point of making a ticket, but before that in my flailing about I almost bricked my pc. Fortunately, Dell Support Assist kicked in and sort of rescued my pc from the dump. They put the system back to original delivery state with Windows 10 Pro. I have to rebuild everything, so there's that. But fortunately, in rebuilding, the first thing I did was get Java and run the admin console. It worked and I'm probably going to ride Windows 10 Pro until I can't. At this point I am so frustrated with Microsoft forcing the update - and you know it's all about the money anyway. Enough from the soapbox. I'll be busy rebuilding both my i7 and my core9. Thanks for trying. FYI, I did everything possible before the thing stopped responding and wouldn't boot. I deleted the file association in the registry and let it find it again. I tried forcing the file association. I tried making sure the start file could find the executable by putting the start file in the java folder. I tried running the file from the command prompt. Microsoft reinstalled Windows 11 so many times that the original Windows 10 recovery information was gone. I might be looking for a new OS. I'm really tired if the drama and wasted time over something that should never happen. Again, Thanks to all who tried to help.
  8. It is interesting to note that I updated two laptops to Windows 11. I just ran the same actions on the other PC, and it worked like a charm. I can tell you the one that works is an older I7 Dell, and the one giving me fits is a newer Dell with an I9, which they've now taken to calling Core 9.
  9. Thanks for the suggestion, Geddy. Unfortunately, no joy. I uninstalled Java, rebooted, reinstalled Java from the website with the correct current version 8.441. I cleared cache again for good measure. I went to the default file setup and selected the .bin folder of Java 8.441 and selected javaws.exe. When I tried to run start.jnlp again it reverted to the same run once merry go round, never putting an icon on the desktop.
  10. I just got communications re-established with Michel's help. This was under Windows 10. Thank you very much for helping me through it. No sooner than having this done, I reacted to Microsoft's impending shutdown of Win10 support. You guessed it, I updated to Windows 11, and it broke me again. I have another machine running Windows 10 and it still works fine. I just cannot get Win 11 to do anything. I downloaded the latest .jnlp file and tried to run it. When it didn't know how to open it, I made Java.exe the default to open those files. It keeps asking me to run it one time, and won't run the file. Any ideas? BTW, the portal does work in Win 11. It seems to be almost like the Win 10 issue, but with a twist. Thanks, George
  11. Thanks to everyone for all the help, especially Michel K. for babysitting me. I really appreciate it The operative word in my case is "Normally 8443" for the port. My system, for whatever reason, decided it should like to be port 8080. Thanks again.
  12. I always save the start.jnlp file. Problem is, when it forgets its IP, it also forgets its port. Finder doesn't find the device without the port. So it's a vicious cycle unless you have the port memorized or recorded somewhere. then knowing the IP along with the port redirect lets finder actually find the EISY.
  13. Michel messaged me through a series of SSI scripts that pointed him to the port that I was missing to add to the IP with the ADD function to the launcher. Until I added the port to the Eisy IP address it was returning "Not Found". It works now, but I am confused as to why the Java app or Eisy "forgets its address and/or port". I can always go fishing to find the IP, but the port, if I forget it, is a problem.
  14. The Java app is new because I uninstalled and reinstalled the current version. I also went to UD and got the latest Start.jnlp file. I always check all 3 boxes and run the finder again. I do run the Brave browser instead of Edge or something else. I don't have a specific firewall configured that I set up. I did just installed a NAS on my network. No idea if it did something on the install, but again, I didn't configure a firewall on the install.
  15. Don't know if this helps, but here's a Java log: Java Web Start 11.441.2.07 Using JRE version 1.8.0_441-b07 Java HotSpot(TM) 64-Bit Server VM JRE expiration date: 6/15/25 12:00 AM console.user.home = C:\Users\gscho ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- Missing Application-Name manifest attribute for: https://isy.universal-devices.com/launcher/isyfinder-3.6.jar Running query on George/100.122.107.49 java.io.FileNotFoundException: C:\Users\gscho\AppData\Local\Temp\udi_launcher.state (The system cannot find the file specified) at java.io.FileInputStream.open0(Native Method) at java.io.FileInputStream.open(Unknown Source) at java.io.FileInputStream.<init>(Unknown Source) at java.io.FileInputStream.<init>(Unknown Source) at com.universaldevices.isyfinder.ISYFinder.restoreState(Unknown Source) at com.universaldevices.isyfinder.ISYFinder.restoreState(Unknown Source) at com.universaldevices.isyfinder.ISYFinder$9.run(Unknown Source) Server is not yet listening Server is not yet listening Server is not yet listening Listening for responses... Asking question Question{qName=_https._tcp.local., qType=PTR, qClass=IN} Asking question Question{qName=_https._tcp.local., qType=PTR, qClass=IN} Response received! Response was not a mDNS response packet, ignoring it Listening for responses... Response received! Response was not a mDNS response packet, ignoring it Listening for responses... No instances of type _https._tcp found
