shergenr
  1. I think Verizon has dropped support for the email to text option. But want to ask a question: My notifications are firing when prescribed, but delivering at random times. Some days later and at 330 am! Got tired of getting the "man your battle stations" sound at all hours of the day so I have deleted the notification node and notifications. Am wondering if I configured it wrong? Seemed really straight forward but I am days new to eisy
  2. shergenr replied to shergenr's topic in eisy
    Wanted to report back on extending the serial plm cable: I simply bought a male to male rj45 coupler and attached it to UDI's serial cable and the 20' Ethernet cable I had been using. It works flawlessly.
  3. shergenr replied to shergenr's topic in eisy
    Thanks Brian. I was hoping that only the 3 pins used by the udi serial adapter and the female Plm port were active. Do you think this is a bad assumption?
  4. shergenr replied to shergenr's topic in eisy
    Okay that sorts out the PLM. I'm greedy - what's the thinking on the zmatter dongle? Can it be placed in a coat closet and provide reliable service? That dongle won't survive the Better Taste Committee which is chaired by my wife if it is to be mounted in direct line of site. Or is the trick to create a network of devices to pass that signal along?
  5. shergenr replied to shergenr's topic in eisy
    Paul, my thinking on extending the serial cable is since it terminates into a male rj45 to extend it would be a simple matter of getting a female rj45 keystone and wire it with either standard a or b on both ends. The pin out is achieved via the serial cable, correct?
  6. shergenr replied to shergenr's topic in eisy
  7. shergenr posted a topic in eisy
    I'm ready to upgrade from isy994 to eisy. In the process of a remodel so I have to relocate my udi box and plm, and have questions about placement of the Plm and z matter dongle. Generally speaking both items operate on usb standards. As I understand, usb signals are limited to 16 feet of wire. Is this correct? Can I use a usb over ip extender for either of these or will it interfere with the signals? Additionally, in terms of placement what are the realities of location of the z matter dongle ? Can these be placed in closets and function well or does it have to be out in the open? Finally in terms of interference: I will likely have to add the wireless module to my elk panel...will this compete/interfere with the signals generated for zmatter and vice versa? Thanks for your help.
  8. shergenr posted a topic in eisy
    Can anyone tell me what's the length of the Serial PLM Kit cable? For some reason UD felt it more pertinent to only provide the weight of the cable an not the length. Also, was wondering if this cable length and the use of USB limits the maximum distance a PLM can be from the EISY? Or can I simply create an extension using RJ45 adapters and Cat5e cable? Thanks for helping.
  9. Yeah by not putting manual at the end of my searches all I was getting was to smarthome and or insteon caches which are not connecting. Thanks for patience! BTW - almost all you will want is on www.manualsdir.com
  10. I would like to get the docs associated with the 2443-222 micro switch, 2477D, 2334-235 and the 2466dw. I looked at the collection on pyinsteon and that seemed more developer-centric than user centric. Anyone have these?
  11. So is there a listing of capacitors for replacement?
  12. Thanks for the info! You think the old version has any real issues?
  13. Thanks for the info! You think the old version has any real issues?
  14. I just received a purchase from eBay seller: IO Link 2540 or device 43. Is this a legit Insteon device or did I get a bootleg? My original which is fried has an Insteon label on it vs this smart home branding. This one is v1.9 1223..am I gonna have issues with it?
  15. Would disconnecting the load lead from the KPL be sufficient, it's hot as hades up in that attic right now?
