sbooke
  1. Thanks for taking the time here. Frankly I have learn a lot more about the interworking's of the console. I am thinking, we went around our *** to get to our elbow solely due to operator error. I had been hitting update in programs and not save changes. At least i think that's it. Program is saved correctly now. I did not save the correction I just did just update. And when you suggested saved, I double checked and it reverted back to status and not control.. Program summary - ran with ran then. And now motion has turned the light on and off twice. .......thanks Issue resolved
  2. i must have been searching for a program that might work. I have put the program back to the above plus changed the line to control, still no joy.
  3. 2 device scenes - 9 3 device scenes - 4 4 ...1 9.....1 11....1 thats it
  4. ok so the options matched and here is the event viewer log. The last couple of lines are a battery out then in restart of the motion sensor. Why is the plm ignoring the motion sense? In the main tab i am there are 3 entries for the motion sensor. Motion bath motion.1 motion; 4d.ef.13 motion enable; 4d.ef.13 tamper again the program is: there have been a few versions of the set to command is default correct?
  5. ok just hit save - guess i needed to hit start first and let it download. see this file PLM Links Table.v5.9.1__Mon 2025.04.07 06.49.02 PM.xml
  6. Here you go the address of the motion sensor is 4D.EF.5F PLM Links Table.v5.9.1__Mon 2025.04.07 10.43.29 AM.xml
  7. sorry plm links show 148 items in count Esiy upgrade was 4 months ago prior to the motion sensor install. i dont see where to grab the infor on the plm? It was replaced a year ago.
  8. ok thanks Motion does not show up in the event view after a trigger. I only have 48 links I am going to bale on using motion in programs, to much trouble
  9. Control did not work what jumpers?
  10. I have tried this which does not work MS works in a scene as a controller, but not in programs Options for MS are factory defaults
  11. I am starting from scratch. from what i can find, this is not intuitive. the fire place example is just to turn on once and then off. i would like the following: Motion sensor to turn a scene or a controller on and off during a time period. The real live example is to turn on the lights in the bathroom for 5 minutes every time motion is detected during the day only. ( we don't want the lights to come on in the middle of the night) I get how to add the motion sensor to a scene to control the scene on and off. I cant figure out how to make the motion sensor turn on and off a scene/controller during a period. Help is appreciated.
  12. Anybody know what the programing content might be to put a motion sensor on a time of day schedule and to turn on a specific scene during that time frame. Thanks
