Help with upgrade
I recently upgraded my 99i to a 994i and I'm having a problem. 1 of my light switches turns off with a scen that it's not in. I restored the switch but it still seems to act like it's in the sean that it's not in. Any suggestions?
Is it reacting to a Scene initiated by an ISY Program/Admin Console or is it reacting to the paddle/button press of another Controller?
That means there are two distinct problems as the device responds to each in a different way.
Suggest running Tools | Diagnostics | Show Device Links Table for the device that is responding to both a Program initiated Scene and a Controller initiated Scene (button/paddle press). Post the Show results along with the Insteon address of the Controller that turns the device On. Run a Show Device Links Table for the Controller device and post that Show result.
Also run Tools | Diagnostics | Event Viewer with LEVEL 3. Run the Program that invokes the Scene that turns the device On and post the event trace along with the PLM Insteon address.
