3-Way Switching and Grouping
Hi,
I finally set up 3-way switching and I grouped them as per instruction, and it works only on local. If I turn it on or off from ISY, the other switch doesn't respond. I just bought this 3 months ago and everything is new to me, I spent all day to figure it out the 3-way switching. :)
That is the way Insteon works. To control both switches together turn the Scene On/Off. When an individual switch is controlled that switch does not control its linked responders. This allows Insteon to control an individual switch without affecting any linked devices.
