Countdown timer programing
ISY Pro
2450 Relay
KeypadLinc 2487S
The A button will only turn on the relay not off. Wait does not trigger
Control '20.FD.D0.A' is switched On
In Scene 'Driveway Lights On' Set '20.F9.C8-Relay' 100% (On Level)
Wait 10 seconds (or 20 min or what ever)
In Scene 'Driveway Lights On' Set '20.F9.C8-Relay' 0% (On Level)
Driveway Scene
button A
relay
Newbee any help would be great.
The Program looks to be using Adjust Scene statements which do not turn the Responder On and Off. Button A is probably a Controller of a Scene with '20.F9.C8-Relay' as a Responder which is why the device turns On to begin with.
Use a Set Scene alone
Set Scene 'SceneRelay' On
Wait 10 minutes
Set Scene 'SceneRelay' Off
or turn the device On/Off directly
Wait 10 minutes
Set '20.F9.C8-Relay Off
If you want the Program to turn the Relay On and Off Button A should not be a Controller in the Scene
