Programming enhancement: SynchroLinc
jwagner010
I know this may be a low priority but I will put it out there anyway given you are looking to update programs this year:
The SynchroLinc has a number of options you can manually set in the Admin console, namely Trigger Threshold, Holdoff and Hysteresis. I would like to be able to set these values within a program eg. Set '' 237Watts (Trigger Threshold)
Thanks for the consideration
Curious, can you give an example use case where you'd use this. Not disagreeing, curious as I considered them 'fixed' states once programmed to a load such as my TV's.
My use case is very simple and somewhat unique I guess, which is why I started off the OP saying this would be low priority but I was hoping maybe something simple to implement for UDI. My SynchroLinc sits in a cupboard above my microwave and has the microwave plugged into it. The Microwave is an over the stove model with a vent, that vents internally. There is a separate exhaust fan in the kitchen. I use the SynchroLinc to turn on the exhaust fan after the microwave has been running longer than 2 minutes. So why do I need this capability in a program? My wife continues to put cereal boxes in the cupboard ontop of the SynchroLinc, pressing the set button on it all the time, throwing out the settings. I want to build a program that at 4am each day resets the settings in case it has changed accidentally.
I am sure folks can think of other cases but mine is very simple !!!
Does that mean I have to make a child before I implement this fix or can I just go to the store and buy some Lego now?
I'm sure there are a few of us here that would gladly send you the last Lego we stepped on barefoot in the dark.
-Xathros
It's a lot of fun in the trying :lol:
A bottle cap would work too, just a bit thicker.
