Mutually Exclusive Groupings
I have a 2475F FanLinc that I need to control with a pair of cross-linked 2487S KeypadLinc Switches. I have been searching this forum and the UDI WIKI but can find no example of using “Mutually Exclusive Groupings†to accomplish this.
If this is possible can someone point me at an example of how to do it?
As an aside, after much browsing of the UDI WIKI I have the following comment:
Not misinformation but samples of what I have been seeing as I browse the WIKI.
• “It is defines the action taken after the condition is met or the trigger occurs.â€
• “…the same set of devices controlled by multiple a Keypadlinc buttons, …â€
• “Along the bottom select the "Mutually Exclusive Buttons" GUI button
Some of the fragments floating around in the WIKI degrade the professionalism of the document.
The WIKI is important enough as a sales tool that setting up an editorial process should be considered.
John Rini
This can be done with Scenes if the KPLs are v.40 or higher. At that KPL firmware the KPLs support another Controller turning Secondary KPL buttons Off with a Scene On. If the KPLs are at lower firmware level then ISY Programs and additional Scenes are required to turn Off the Secondary buttons on the Responder KPL that is below v.40 firmware
Scene Low
KPL1 button A – Controller
KPL1 button B – Responder 0% On Level
KPL1 button C – Responder 0% On Level
KPL2 button D – Responder 0% On Level
KPL2 button A – Controller
KPL2 button B – Responder 0% On Level
KPL2 button C – Responder 0% On Level
FanLinc Motor – Low
Scene Med
KPL1 button B – Controller
KPL1 button A – Responder 0% On Level
KPL2 button B – Controller
KPL2 button A – Responder 0% On Level
FanLinc Motor – Med
Scene High
KPL1 button C – Controller
KPL2 button C – Controller
FanLinc Motor – High
Scene Off
KPL1 button D – Controller
KPL2 button D – Controller
FanLinc Motor - Off
