March 23, 201313 yr Will this program properly trigger the state of the variable when the thermostat is between 50 and 64? Is this the best way to do it? If From 12:00:01AM To 11:59:00PM (same day) And ( Status 'Thermostats / Third Floor Thermostat' is 50° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 51° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 52° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 53° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 54° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 55° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 56° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 57° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 58° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 59° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 60° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 61° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 62° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 63° (Temperature ) Or Status 'Thermostats / Third Floor Thermostat' is 64° (Temperature ) ) And ( $sMonth < 5 Or $sMonth > 9 ) Then $sCold.on.3rd.Floor = 1 Else Wait 10 minutes Run Program 'Cold.on.3rd.Floor' (If)
March 23, 201313 yr I expect that this program will set the "cold on third floor" variable, if the month variables are within range and temperature is between 50 and 64, inclusive. At midnight, it will execute the "else" path every time, regardless of other conditions. Of coure, the wait period will hold any real action off until 1201.
March 23, 201313 yr The temperature range can be done with If Status '2441TH - Main' >= 50° (Temperature) And Status '2441TH - Main' <= 64° (Temperature)
March 24, 201313 yr Author I really missed the fact that we can now act on temp, when was that released? That makes things MUCH easier!
