Is it cold?
Will this program properly trigger the state of the variable when the thermostat is between 50 and 64? Is this the best way to do it?
       From    12:00:01AM
       To      11:59:00PM (same day)
   And (
            Status  'Thermostats / Third Floor Thermostat' is 50° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 51° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 52° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 53° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 54° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 55° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 56° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 57° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 58° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 59° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 60° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 61° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 62° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 63° (Temperature )
         Or Status  'Thermostats / Third Floor Thermostat' is 64° (Temperature )
   And (
            $sMonth < 5
         Or $sMonth > 9
       $sCold.on.3rd.Floor  = 1
       Wait  10 minutes
       Run Program 'Cold.on.3rd.Floor' (If)
I expect that this program will set the "cold on third floor" variable, if the month variables are within range and temperature is between 50 and 64, inclusive.
At midnight, it will execute the "else" path every time, regardless of other conditions. Of coure, the wait period will hold any real action off until 1201.
