I simply want to set a timer that if a switch is on for a set time it will shut off. How do I set that up?
+1. I use that exact same program to auto turn off several of my devices (bathroom lights, closet lights, and bathroom ventilation fans). Works perfectly. Plus, if someone turns the light/fan off and then someone else turns it back on, it will reset the shut-off timer.
Please note that this program is effective only for when switches are manually turned on. The program will not trigger when a switch is activated as part of a program or a scene.
