Inline Linc with Sense.
Is it possible to have ISY use the sense lead of the InlineLinc to trigger a program WITHOUT turning on the InlineLincs load?
Situation I want to have the motion sensor that the InlineLinc is connected to trigger a program without turning on the flood lights during the day.
Since ISY seems to only see a single state for the InlineLinc I am guessing the answer is probably no.
One other question, anyone know what the Blue "Switch In" wire on the InlineLinc is for and why you would ever wiring it separately from the black hot line?
The answer to the first question is No.
The Blue wire, which is normally connected to Line, can be disconnected from Line allowing the InLineLinc Relay to be used as a dry contact NO relay.
