"Irrigation Requirement" - When does this calculated?
Hi,
I upgraded the latest version recently and I have irrigation runs at 5am when the requirement is > 0.3, this morning the value is 0.38 but the irrigation didn't started at 5am. Normally the value gets calculated at midnight. I was wondering if the latest version calculates the value in different time than the previous one.
Thank you.
Hello dpark,
The calculation times have not changed in recent versions. Irrigation Required is still calculated at midnight.
If you are currently seeing Irrigation Required as 0.38, it should have been the same value at 5:00 AM.
Would you mind posting your program? It's possible that another condition prevented it from running.
IM
Thanks IndyMike.
There are other factors might have caused this, such as weather temperature check since I'm using the Irrigation Module V2. I'm going to move the temperature logic(I don't think I need this) and see what happens. I'll update this post if it happens again.
Thanks again.
