Not sure what the problem could be
I've had Comm errors in the past and have discovered that it's related to when my desktop is running.
I always put my computer on standby mode (never actually powered off)and when I do that the errors go away.
I bought a 10 amp Filterlinc and put it on the powerbar that all the computer and related devices are plugged in to and it doesn't seem to do anything. The comm errors are still there and go away when the computer is in standby.
I don't understand what can be wrong.
Drew
The PLM and the ISY are plugged into an outlet in the same room but on a different circuit.
Do you think it's interference somehow?
Drew
Certainly sounds like powerline noise from the power supply, but I'm surprised the FilterLinc did not help.
Do you have another power supply you could try?
The outlet might have a faulty ground connection. One way to rule this out would be to move the PC to another nearby circuit (without the powerstrip or peripherals to start) and see if the problem persists.
-Jim
The outlet is fine. I've replaced the outlet with a Decora not too long ago and checked my work with the tester.
I can move the computer to a different room.
I could just put it on an extension cord and run the cord to different outlets (easy to do) or should I move the actual computer? (bit of a pain)
Is the Filterlinc useless then?
Drew
Drew
Perhaps the monitor is the culprit.
Drew
I don't think using an extension cord (3-prong) would have any effect.
      37.6k
      376.2k
