Program ran at startup that was not supposed to
ISY had to be rebooted last week (as part of installing Mobilinc Connect). At startup the following program ran true. This is quite strange because time was about 6 PM, the program is NOT enabled to "run at startup" (see screenshot) and it certainly didn't use to run at startup.
I manually rebooted ISY this morning again (at about 5:15AM) to test this and the program ran again (see screenshot).
Am on 4.0.5.
       Time is 12:00:10AM
       $iDehumidifer.Halloween.Xmas.ManuallyOFF  = 0
       $iDehumidifer.Halloween.Xmas.ManuallyON  = 0
       Run Program 'Daily HVAC Resets' (Then Path)
Could this problem be related to viewtopic.php?f=27&t=11873?
Yep, that's it. I only turned it on a few months ago and last week was no doubt the first time ISY rebooted since I did it.
I guess I'll have to move my daily reset to 11:59PM (given that catch up only goes back 12:00AM) and will have to check other programs that might be in the same boat but haven't caught my eye.
