Programming question
I have a simple program that runs in a time slot and that turns on a bathroom fan if the humidity (reported from a wireless thermostat) exceeds a certain number and turns it off if the humidity goes below that number. The else line currently reads "else set bath fan off"
How can I also program the switch to turn on the fan manually and stay on until I manually turn it off thus overriding the above program?
I do this using a variable to determine if the fan was manually turned on or not. Something like this:
  (  Control Bathroom Fan is Switched On
  Or Control Bathroom Fan is switched FastOn
  And
  (  Control Bathroom Fan is not Switched Off
  or Control Bathroom Fan is not Switched Fast Off
  $i.AutoFanDisable=1
  $i.AutoFanDisable=0
  #s.BathroomHumid >= 65
  And i.AutoFanDisable=0
  Set Bathroom Fan On
If $s.BathroomHumid < 65
  And i.AutoFanDisable = 0
  Set Bathroom Fan Off
-Xathros
Xanthros' program should work beautifully (and thanks for sharing) but my question is, How are you reading the wireless thermostat / humidistat values via ISY? That's exactly what I've been hoping to do, but didn't know was possible. I formerly used HomeSeer with Oregon Scientific sensors and an RFXCom, and temp / humidity is my last frontier in terms of replacing it with ISY and my Elk. Thanks for any info you can share.
Ah - Makes sense - Thank You!
I keep hoping for some way to read remote temp / humidity sensors (like those from Oregon Scientific) into the ISY or the Elk. It's the last thing I need to eliminate a PC from my system.
