Ethernet codes
In making a final home for ISY, I need to make a long patch cable for ISY from the modem. I use Leviton modular outlets. They can be wired 568 A or B. What do you use for your protocol? If you just let me know the colors of the "8" wires from 1-8, I'd appreciate it.
aLf
It should not matter as long as both ends are wired the same. However, 586B is the standard typically used for data cabling.
