A few things I've done with Mobilinc and Tasker
Do variable splits EXACTLY like I did above. If you paste that code into Tasker, it should create all the actions. If not, I'll export the xml for you
Sent from my XT1060 using Tapatalk
I tried the code below just to test if variable but this did not change from ON to OFF or vice versa.
  A3: HTTP Get [ Server:Port:%HALURL Path:/rest/status/%NODEFDOOR Attributes: Cookies: Timeout:10 Mime Type: Output File: Trust Any Certificate:Off ]
  A4: Variable Set [ Name:%status To:%HTTPD Do Maths:Off Append:Off ]
  A5: Variable Split [ Name:%status Splitter:<?xml version="1.0" encoding="UTF-8"?>
Do I have the correct output format? What is best "variable split" format should I use?
Did you use my task? The variable splits were already written to use the XML that it creates when you address any node on the isy via the rest API..
You have to split the output 3 times to get the proper values. And anything with more than 0 is sets the Tasker variable %HALFDOOR to ON
Yes, I used your task and I did not get the correct results. I was thinking that maybe because my HTTPD format was different from yours? What do you think?
can you get on google hangouts?
My user name here @gmail.com
Ok. will message you now.
Or would you be able to send me your XML file.
1401806636236
277
NFC/AV-Front Door
10
118
%HALURL
/rest/nodes/%NODEFDOOR/cmd/DON
text/xml
%HALFDOOR
0
OFF
118
%HALURL
/rest/nodes/%NODEFDOOR/cmd/DOF
text/xml
%HALFDOOR
0
ON
66
Light Control
Front Door Icon
/mnt/sdcard/Tasker/icons/landscapeLightsOFF-44x44@2x.png
%HALFDOOR
0
OFF
38
28490
Set HAL-Patio Light PowerToggle to on
java.lang.String
varID state
java.lang.String
true
java.lang.Boolean
true
java.lang.String
java.lang.String
com.painless.pc
Modify PowerToggle state
%HALFDOOR
0
ON
28490
Set HAL-Patio Light PowerToggle to off
java.lang.String
varID state
java.lang.String
true
java.lang.Boolean
false
java.lang.String
java.lang.String
com.painless.pc
%HALFDOOR
0
OFF
31664
#TFdoor# = %HALFDOOR
java.lang.String
org.zooper.zw.tasker.var.extra.STRING_TEXT
java.lang.String
true
java.lang.Boolean
1
java.lang.Integer
%HALFDOOR
java.lang.String
Fdoor
java.lang.String
org.zooper.zwpro
Zooper Widget Pro Variable
300
End
118
Front Door
%HALURL
547
%status
%HTTPD
590
%status
<?xml version="1.0" encoding="UTF-8"?><properties><property id="ST" value="
590
%status2
" formatted="
547
%HALFDOOR
ON
%status21
3
0
547
%HALFDOOR
OFF
%status21
2
1
37
%HALSCN
0
ON
66
Light Control
Front Door Icon
/mnt/sdcard/Tasker/icons/landscapeLightsON-44x44@2x.png
%HALFDOOR
0
ON
hd_aaa_ext_bulb
Let me strip all my addins out and send that again
This should be better:
1371767176158
1402022884210
243
NFC/AV-Front Door 2Share
10
118
%HALURL
text/xml
%HALFDOOR
0
OFF
118
%HALURL
text/xml
%HALFDOOR
0
ON
118
Front Door
%HALURL
547
%status
%HTTPD
590
%status
590
%status2
" formatted="
547
%HALFDOOR
ON
%status21
3
0
547
%HALFDOOR
OFF
%status21
2
1
300
End
hd_aaa_ext_bulb
Put that code in a file and call it tasksample.tsk.xml
Place it in sdcard/Tasker/tasks then use Tasker to import it by going to the tasks tab then long press the tasks tab and import
  • 3 weeks later...
Where did you find the icons for Zooper? I'm looking all over google images for something.
Who's Wes? Those icon's look good.
I'm following along this post, almost got it. Just working out network resources sending URL to autoremotejoaomgcd.com. Keeps coming back TCP client request failed. I can manually send them from the PC and the cell phone acts accordingly. Just not from ISY.
Also was wondering, how you are using the tasker scene? Is tasker scene changing the icon from on to off, or zooper widget?
Wes is the creator of mobilinc..
Show me a screenshot of one of your network objects to send a message to the phone.
Of course, blur out the api keys.
Zooper is on the main screen that makes a call to send the on/off code, then, the ISY sends a msg back to the phone to reflect its new status..
Message: lightstatus=:=lrlamp=:=on
Profile:
auto remote message: lightstatus
Task:
If %arcomm2 = on
Variable set %LRLAMP to ON if
%arcomm1 = lrlamp
Keep adding to that task for each light.
This should be a good starter.
Sent from my Moto X
I'm trying to get rid of repetitive tasks/code. I like your code of tasks you posted earlier, gave me a good starting point.
Your %%arcomm(1) = %arcomm(2) was genius and will cut down on repetitive code.
I'm trying to see if Zooper Widget Variable plugin can handle the same thing but without luck so far.
example
#T%HouseRoom# = %onoff
I don't want to do IF statements for each room/light.
Question on your changing icons to show on/off. Do you use Zooper bitmap icon set, or can tasker change the icon right from the task?
Zooper widgets are written as #Tlrlamp# . No percent in those..
Let me export my profile.. This took me days to develop.
Sent from my Moto X
Ya I am trying to find a way to pass a Tasker variable that contains the name of the ZW variable.
Just like we could in Tasker with %% reference.
Tasker
%HouseRoom = "bedroom"
%onoff = "on"
ZW plug-in
Which would equate to #Tbedroom# = on
That way I don't have to have 100 of IF/ElseIf states for each ZW variable.
Thanks, I'm starting to look into your code.!
What you want to do isn't possible with the zw plugin.. They won't even allow you to use local variables
Sent from my Moto X
