Looking for programming ideas
Looking for help with writing a program in my isy994i that will identify the state, when and if a program was executed. In a nutshell, I have two applications that I controll via my isy... XBMC and Windows MCE. Using network resources I have successfully created a program that will launch and close both applications.
The problem that I am running into is that I'm not able to identify the state of these programs. Nonetheless, After doing some reading through the wiki and some threads I don't fully understand how to use the variable options that are available. My ultimate goal is to prevent both XBMC and MCE from running at the same time.
Here is what I have tried so far that doesn't seem to work.
Network Resources that were created include:
* Open XBMC
XBMC variable state = 1
* Close XBMC
XBMC variable state = 0
* Open MCE
MCE variable state = 1
* Close MCE
MCE variable state = 0
Program created
*Open XBMC
IF
MCE = 0
and XBMC = 0
Resouce XBMC (Open XBMC)
When I run the if statement all it does is open and closes both applications repeatedly and it won't stop until I reset the HTPC.
Any help with resolving this looping issue would be appreciated.
I think we need to see more of your programs. Specifically, I would like to see the programs that call the resources and set the values of the state variables.
-Xathros
Xathros,
Thanks for the reply. Not sure I understand your question. The only program that calls the resource is as follows:
Open XBMC (program) run if
if
MCE = 0
and XBMC = 0
Then how are you setting the values for the variables XBMC and MCE ? With only that one program, I see no way for a loop to happen here. What does the Network Resource look like?
I would think you would have a program that says:
Program: Turn On XBMC:
If MCE = 0
  and XBMC =  0
  Resource TurnOnXBMC
  XBMC = 1
and a program like:
Program: Turn Off XBMC:
If XBMC = 1
  Resource TurnOIffXBMC
  XBMC = 0
and:
Program: Turn On MCE
If MCE=0
  and XBMC = 0
  Resource TurnOnMCE
  MCE = 1
and finally:
Program: Turn Off MCE
If MCE = 1
  Resource TurnOffMCE
  MCE = 0
In the above examples, all variables are Integer - Not State variables.
-Xathros
Ok, I think I understand now. My apology for not being clear. I am working from a different computer and off of my memory at the moment and I do not have remote access to my isy to see the program that I created.
That said, I will post a reply this evening when I get access to my isy.
