bsobel Posted November 27, 2013 Share Posted November 27, 2013 Access Points have no configuration. Plug them in and they couple if in range of each other and on opposite 120v legs. LeeG don't they relay regardless of which leg they are in as long as they are range of each other? Link to comment Share on other sites More sharing options...
bsobel Posted November 27, 2013 Share Posted November 27, 2013 I think I need to suck it up and do that (upgrade the PLM). I need to try the hardwire phase coupler without the Access Points, too. Once I have the dual-band PLM. I shouldn't need the Access Points. Alternatively, is there some way to factory reset the Access Points so that they are not bridging phases but just bridging RF with PLC? As LeeG said, no configuration on the access points. I highly recommend NOT removing them in fact adding more may be the easiest way to mask some of your (probable) power line issues. I have one in almost every room here as well as some mounted outside to relay to the other structures. Link to comment Share on other sites More sharing options...
Brian H Posted November 27, 2013 Share Posted November 27, 2013 oronomus; The Phase Bridge Detection Beacon or four tap test. Best to read the Quick Users Guide or Full Users Manual for exact directions and indications. For most Dual Band devices is tapping the Set Button four times to start the test. Recent things like the DIN Rail Modules seem to use a different way to start it. 2413S PLM as an example will start beeping its beeper and its LED will be solid Green. Older modules the LED on the side may change color or get bright. Then you look at your other Dual Band devices LED and observe it actions. Again older hardware modules may act different. Dual color LEDs will flash Green if receiving and on the opposite phase. Red if receiving and on same phase. While a Version 1.? 2443 Access Point will light its White or Blue LED brightly if receiving and on the opposite phase. You do not have to have communications between every module to every other module in your system. At least one or more properly communicating is needed. Link to comment Share on other sites More sharing options...
LeeG Posted November 27, 2013 Share Posted November 27, 2013 bsobel Powerline is repeated on RF and RF is repeated on powerline regardless of whether they are coupling the two 120v legs. Link to comment Share on other sites More sharing options...
