Replacing Relay KPL with Dimmer KPL
Is there a quick way to replace/reprogram a dimmer KPL for a relay based KPL? I have used the menu item that lets me replace items of the same basic type, ie dimmer KPL for a dimmer KPL, or switchlinc relay for a switchlinc relay. But not when I am changing from relay KPL to a dimmer KPL. These are both KPL-8s and have a lot of programming and scene linkages that will be time consuming to reprogram..... If not, so be it, but I have often missed shortcuts....
The device types have to be the same, Dimmer for Dimmer, Relay for Relay. Not a problem replacing an ICON Relay with a SwitchLinc Relay but replacing a Dimmer with a Relay (or reverse) is not supported.
