Run program B if program A is disabled
Any tips on how to approach this would be appreciated. I want to text myself a reminder daily if the program that runs my lawn sprinklers has been disabled. I don't see how make program B (the notification program), which would be the assessment of whether program A (the sprinkler program) is disabled, assess whether program A is indeed disabled.
I'm trying to approach this as two different programs, but as so often happens with programming, there's often a better way, so I'm stepping back from this and hoping someone can suggest how to do this...
Thanks everyone.
Bill
The only way I can think of to test the enabled status of a program is to include something in the If of that program that is a trigger event and use the other program to create a trigger event for the first program. Then that program would trigger an email from the else clause only if it is enabled. If it weren't enable you would get no notification.
Time is whenever you want to irrigate
and state.variable.a = 1
irrigate
notify . . .
time is whenever you want to be notified
state.variable.a = 0
optionally add a notify here to remind you that if you don't get a notify from your irrigation program that it must be disabled.
Unfortunately this will send 2 notifications, but that is all I can think of right now.
There may well be a better way but of late I have taken to generating lots of "state" variables that reflect the state of my house and can be used in tests like your if and also can trigger programs when they change. You simplest bet might be to have a variable that represents the state of the sprinkler system and set it anyplace that you disable the sprinkler program. A bit risky since you might not get it everywhere. So using my approach of late I wouldn't disable the sprinkler program - I'd use that state variable in the program to have it not execute. That way the state of the sprinkler system would be fully represented by that one variable.
Thanks everyone.
Bill
If all you are looking for is a daily email with the enabled state of a program, just make a daily notification program. The customized notification text would have something like:
${sys.program.#.enabled}
${sys.program.#.name}
Replace the # with the number of your program. I would also include the Name in there until you are sure you have the right program, as this is a number and I don't think adding the letters in from the ID works.
Also note with this, you'll recieve either a True or a False for the enabled status. I don't think you can not send the email if it is false unless you get deeper than I am with network resources and do some trickery there.
Just to clarify, the # is for the program you are testing (the irrigation one) and not the number of the program that is generating the daily notification event.
If you leave just the # in there it will use the number of the notification program automatically.
Thanks everyone.
Bill
y
2 questions.
1) Where did you get those variable substitutions. This is all that is on the wiki. http://wiki.universal-devices.com/index ... _Variables
2) on my system it is only working on programs with decimal ID. In other words, 001B does not work, but 0012 does
Thanks everyone. Your suggestions are probably a bit beyond my Unix Shell programming courses of 30 years ago, but I'll roll up my sleeves and see what trouble I can create. Thanks again.
2 questions.
1) For the variable, I just added the Name variable and then edited it to Enabled. It was a shot in the dark.
2) This is correct, and the reason I stated above that you would have to find the right number.
I'll give you a copy / paste for that. My program Heating Current SP 73 has an ID of 009D. The number for it is 157.
Paste the following code into your notification customization body:
1) ${sys.program.1.name}: ${sys.program.1.enabled}
2) ${sys.program.2.name}: ${sys.program.2.enabled}
3) ${sys.program.3.name}: ${sys.program.3.enabled}
4) ${sys.program.4.name}: ${sys.program.4.enabled}
5) ${sys.program.5.name}: ${sys.program.5.enabled}
6) ${sys.program.6.name}: ${sys.program.6.enabled}
7) ${sys.program.7.name}: ${sys.program.7.enabled}
 ${sys.program.8.name}: ${sys.program.8.enabled}
9) ${sys.program.9.name}: ${sys.program.9.enabled}
10) ${sys.program.10.name}: ${sys.program.10.enabled}
11) ${sys.program.11.name}: ${sys.program.11.enabled}
12) ${sys.program.12.name}: ${sys.program.12.enabled}
13) ${sys.program.13.name}: ${sys.program.13.enabled}
14) ${sys.program.14.name}: ${sys.program.14.enabled}
15) ${sys.program.15.name}: ${sys.program.15.enabled}
16) ${sys.program.16.name}: ${sys.program.16.enabled}
17) ${sys.program.17.name}: ${sys.program.17.enabled}
18) ${sys.program.18.name}: ${sys.program.18.enabled}
19) ${sys.program.19.name}: ${sys.program.19.enabled}
20) ${sys.program.20.name}: ${sys.program.20.enabled}
21) ${sys.program.21.name}: ${sys.program.21.enabled}
22) ${sys.program.22.name}: ${sys.program.22.enabled}
23) ${sys.program.23.name}: ${sys.program.23.enabled}
24) ${sys.program.24.name}: ${sys.program.24.enabled}
25) ${sys.program.25.name}: ${sys.program.25.enabled}
26) ${sys.program.26.name}: ${sys.program.26.enabled}
27) ${sys.program.27.name}: ${sys.program.27.enabled}
28) ${sys.program.28.name}: ${sys.program.28.enabled}
29) ${sys.program.29.name}: ${sys.program.29.enabled}
30) ${sys.program.30.name}: ${sys.program.30.enabled}
31) ${sys.program.31.name}: ${sys.program.31.enabled}
32) ${sys.program.32.name}: ${sys.program.32.enabled}
33) ${sys.program.33.name}: ${sys.program.33.enabled}
34) ${sys.program.34.name}: ${sys.program.34.enabled}
35) ${sys.program.35.name}: ${sys.program.35.enabled}
36) ${sys.program.36.name}: ${sys.program.36.enabled}
37) ${sys.program.37.name}: ${sys.program.37.enabled}
38) ${sys.program.38.name}: ${sys.program.38.enabled}
39) ${sys.program.39.name}: ${sys.program.39.enabled}
40) ${sys.program.40.name}: ${sys.program.40.enabled}
41) ${sys.program.41.name}: ${sys.program.41.enabled}
42) ${sys.program.42.name}: ${sys.program.42.enabled}
43) ${sys.program.43.name}: ${sys.program.43.enabled}
44) ${sys.program.44.name}: ${sys.program.44.enabled}
45) ${sys.program.45.name}: ${sys.program.45.enabled}
46) ${sys.program.46.name}: ${sys.program.46.enabled}
47) ${sys.program.47.name}: ${sys.program.47.enabled}
48) ${sys.program.48.name}: ${sys.program.48.enabled}
49) ${sys.program.49.name}: ${sys.program.49.enabled}
50) ${sys.program.50.name}: ${sys.program.50.enabled}
51) ${sys.program.51.name}: ${sys.program.51.enabled}
52) ${sys.program.52.name}: ${sys.program.52.enabled}
53) ${sys.program.53.name}: ${sys.program.53.enabled}
54) ${sys.program.54.name}: ${sys.program.54.enabled}
55) ${sys.program.55.name}: ${sys.program.55.enabled}
56) ${sys.program.56.name}: ${sys.program.56.enabled}
57) ${sys.program.57.name}: ${sys.program.57.enabled}
58) ${sys.program.58.name}: ${sys.program.58.enabled}
59) ${sys.program.59.name}: ${sys.program.59.enabled}
60) ${sys.program.60.name}: ${sys.program.60.enabled}
61) ${sys.program.61.name}: ${sys.program.61.enabled}
62) ${sys.program.62.name}: ${sys.program.62.enabled}
63) ${sys.program.63.name}: ${sys.program.63.enabled}
64) ${sys.program.64.name}: ${sys.program.64.enabled}
65) ${sys.program.65.name}: ${sys.program.65.enabled}
66) ${sys.program.66.name}: ${sys.program.66.enabled}
67) ${sys.program.67.name}: ${sys.program.67.enabled}
68) ${sys.program.68.name}: ${sys.program.68.enabled}
69) ${sys.program.69.name}: ${sys.program.69.enabled}
70) ${sys.program.70.name}: ${sys.program.70.enabled}
71) ${sys.program.71.name}: ${sys.program.71.enabled}
72) ${sys.program.72.name}: ${sys.program.72.enabled}
73) ${sys.program.73.name}: ${sys.program.73.enabled}
74) ${sys.program.74.name}: ${sys.program.74.enabled}
75) ${sys.program.75.name}: ${sys.program.75.enabled}
76) ${sys.program.76.name}: ${sys.program.76.enabled}
77) ${sys.program.77.name}: ${sys.program.77.enabled}
78) ${sys.program.78.name}: ${sys.program.78.enabled}
79) ${sys.program.79.name}: ${sys.program.79.enabled}
80) ${sys.program.80.name}: ${sys.program.80.enabled}
81) ${sys.program.81.name}: ${sys.program.81.enabled}
82) ${sys.program.82.name}: ${sys.program.82.enabled}
83) ${sys.program.83.name}: ${sys.program.83.enabled}
84) ${sys.program.84.name}: ${sys.program.84.enabled}
85) ${sys.program.85.name}: ${sys.program.85.enabled}
86) ${sys.program.86.name}: ${sys.program.86.enabled}
87) ${sys.program.87.name}: ${sys.program.87.enabled}
88) ${sys.program.88.name}: ${sys.program.88.enabled}
89) ${sys.program.89.name}: ${sys.program.89.enabled}
90) ${sys.program.90.name}: ${sys.program.90.enabled}
91) ${sys.program.91.name}: ${sys.program.91.enabled}
92) ${sys.program.92.name}: ${sys.program.92.enabled}
93) ${sys.program.93.name}: ${sys.program.93.enabled}
94) ${sys.program.94.name}: ${sys.program.94.enabled}
95) ${sys.program.95.name}: ${sys.program.95.enabled}
96) ${sys.program.96.name}: ${sys.program.96.enabled}
97) ${sys.program.97.name}: ${sys.program.97.enabled}
98) ${sys.program.98.name}: ${sys.program.98.enabled}
99) ${sys.program.99.name}: ${sys.program.99.enabled}
100) ${sys.program.100.name}: ${sys.program.100.enabled}
101) ${sys.program.101.name}: ${sys.program.101.enabled}
102) ${sys.program.102.name}: ${sys.program.102.enabled}
103) ${sys.program.103.name}: ${sys.program.103.enabled}
104) ${sys.program.104.name}: ${sys.program.104.enabled}
105) ${sys.program.105.name}: ${sys.program.105.enabled}
106) ${sys.program.106.name}: ${sys.program.106.enabled}
107) ${sys.program.107.name}: ${sys.program.107.enabled}
108) ${sys.program.108.name}: ${sys.program.108.enabled}
109) ${sys.program.109.name}: ${sys.program.109.enabled}
110) ${sys.program.110.name}: ${sys.program.110.enabled}
111) ${sys.program.111.name}: ${sys.program.111.enabled}
112) ${sys.program.112.name}: ${sys.program.112.enabled}
113) ${sys.program.113.name}: ${sys.program.113.enabled}
114) ${sys.program.114.name}: ${sys.program.114.enabled}
115) ${sys.program.115.name}: ${sys.program.115.enabled}
116) ${sys.program.116.name}: ${sys.program.116.enabled}
117) ${sys.program.117.name}: ${sys.program.117.enabled}
118) ${sys.program.118.name}: ${sys.program.118.enabled}
119) ${sys.program.119.name}: ${sys.program.119.enabled}
120) ${sys.program.120.name}: ${sys.program.120.enabled}
121) ${sys.program.121.name}: ${sys.program.121.enabled}
122) ${sys.program.122.name}: ${sys.program.122.enabled}
123) ${sys.program.123.name}: ${sys.program.123.enabled}
124) ${sys.program.124.name}: ${sys.program.124.enabled}
125) ${sys.program.125.name}: ${sys.program.125.enabled}
126) ${sys.program.126.name}: ${sys.program.126.enabled}
127) ${sys.program.127.name}: ${sys.program.127.enabled}
128) ${sys.program.128.name}: ${sys.program.128.enabled}
129) ${sys.program.129.name}: ${sys.program.129.enabled}
130) ${sys.program.130.name}: ${sys.program.130.enabled}
131) ${sys.program.131.name}: ${sys.program.131.enabled}
132) ${sys.program.132.name}: ${sys.program.132.enabled}
133) ${sys.program.133.name}: ${sys.program.133.enabled}
134) ${sys.program.134.name}: ${sys.program.134.enabled}
135) ${sys.program.135.name}: ${sys.program.135.enabled}
136) ${sys.program.136.name}: ${sys.program.136.enabled}
137) ${sys.program.137.name}: ${sys.program.137.enabled}
138) ${sys.program.138.name}: ${sys.program.138.enabled}
139) ${sys.program.139.name}: ${sys.program.139.enabled}
140) ${sys.program.140.name}: ${sys.program.140.enabled}
141) ${sys.program.141.name}: ${sys.program.141.enabled}
142) ${sys.program.142.name}: ${sys.program.142.enabled}
143) ${sys.program.143.name}: ${sys.program.143.enabled}
144) ${sys.program.144.name}: ${sys.program.144.enabled}
145) ${sys.program.145.name}: ${sys.program.145.enabled}
146) ${sys.program.146.name}: ${sys.program.146.enabled}
147) ${sys.program.147.name}: ${sys.program.147.enabled}
148) ${sys.program.148.name}: ${sys.program.148.enabled}
149) ${sys.program.149.name}: ${sys.program.149.enabled}
150) ${sys.program.150.name}: ${sys.program.150.enabled}
151) ${sys.program.151.name}: ${sys.program.151.enabled}
152) ${sys.program.152.name}: ${sys.program.152.enabled}
153) ${sys.program.153.name}: ${sys.program.153.enabled}
154) ${sys.program.154.name}: ${sys.program.154.enabled}
155) ${sys.program.155.name}: ${sys.program.155.enabled}
156) ${sys.program.156.name}: ${sys.program.156.enabled}
157) ${sys.program.157.name}: ${sys.program.157.enabled}
158) ${sys.program.158.name}: ${sys.program.158.enabled}
159) ${sys.program.159.name}: ${sys.program.159.enabled}
160) ${sys.program.160.name}: ${sys.program.160.enabled}
161) ${sys.program.161.name}: ${sys.program.161.enabled}
162) ${sys.program.162.name}: ${sys.program.162.enabled}
163) ${sys.program.163.name}: ${sys.program.163.enabled}
164) ${sys.program.164.name}: ${sys.program.164.enabled}
165) ${sys.program.165.name}: ${sys.program.165.enabled}
166) ${sys.program.166.name}: ${sys.program.166.enabled}
167) ${sys.program.167.name}: ${sys.program.167.enabled}
168) ${sys.program.168.name}: ${sys.program.168.enabled}
169) ${sys.program.169.name}: ${sys.program.169.enabled}
170) ${sys.program.170.name}: ${sys.program.170.enabled}
171) ${sys.program.171.name}: ${sys.program.171.enabled}
172) ${sys.program.172.name}: ${sys.program.172.enabled}
173) ${sys.program.173.name}: ${sys.program.173.enabled}
174) ${sys.program.174.name}: ${sys.program.174.enabled}
175) ${sys.program.175.name}: ${sys.program.175.enabled}
176) ${sys.program.176.name}: ${sys.program.176.enabled}
177) ${sys.program.177.name}: ${sys.program.177.enabled}
178) ${sys.program.178.name}: ${sys.program.178.enabled}
179) ${sys.program.179.name}: ${sys.program.179.enabled}
180) ${sys.program.180.name}: ${sys.program.180.enabled}
181) ${sys.program.181.name}: ${sys.program.181.enabled}
182) ${sys.program.182.name}: ${sys.program.182.enabled}
183) ${sys.program.183.name}: ${sys.program.183.enabled}
184) ${sys.program.184.name}: ${sys.program.184.enabled}
185) ${sys.program.185.name}: ${sys.program.185.enabled}
186) ${sys.program.186.name}: ${sys.program.186.enabled}
187) ${sys.program.187.name}: ${sys.program.187.enabled}
188) ${sys.program.188.name}: ${sys.program.188.enabled}
189) ${sys.program.189.name}: ${sys.program.189.enabled}
190) ${sys.program.190.name}: ${sys.program.190.enabled}
191) ${sys.program.191.name}: ${sys.program.191.enabled}
192) ${sys.program.192.name}: ${sys.program.192.enabled}
193) ${sys.program.193.name}: ${sys.program.193.enabled}
194) ${sys.program.194.name}: ${sys.program.194.enabled}
195) ${sys.program.195.name}: ${sys.program.195.enabled}
196) ${sys.program.196.name}: ${sys.program.196.enabled}
197) ${sys.program.197.name}: ${sys.program.197.enabled}
198) ${sys.program.198.name}: ${sys.program.198.enabled}
199) ${sys.program.199.name}: ${sys.program.199.enabled}
200) ${sys.program.200.name}: ${sys.program.200.enabled}
201) ${sys.program.201.name}: ${sys.program.201.enabled}
202) ${sys.program.202.name}: ${sys.program.202.enabled}
203) ${sys.program.203.name}: ${sys.program.203.enabled}
204) ${sys.program.204.name}: ${sys.program.204.enabled}
205) ${sys.program.205.name}: ${sys.program.205.enabled}
206) ${sys.program.206.name}: ${sys.program.206.enabled}
207) ${sys.program.207.name}: ${sys.program.207.enabled}
208) ${sys.program.208.name}: ${sys.program.208.enabled}
209) ${sys.program.209.name}: ${sys.program.209.enabled}
210) ${sys.program.210.name}: ${sys.program.210.enabled}
211) ${sys.program.211.name}: ${sys.program.211.enabled}
212) ${sys.program.212.name}: ${sys.program.212.enabled}
213) ${sys.program.213.name}: ${sys.program.213.enabled}
214) ${sys.program.214.name}: ${sys.program.214.enabled}
215) ${sys.program.215.name}: ${sys.program.215.enabled}
216) ${sys.program.216.name}: ${sys.program.216.enabled}
217) ${sys.program.217.name}: ${sys.program.217.enabled}
218) ${sys.program.218.name}: ${sys.program.218.enabled}
219) ${sys.program.219.name}: ${sys.program.219.enabled}
220) ${sys.program.220.name}: ${sys.program.220.enabled}
221) ${sys.program.221.name}: ${sys.program.221.enabled}
222) ${sys.program.222.name}: ${sys.program.222.enabled}
223) ${sys.program.223.name}: ${sys.program.223.enabled}
224) ${sys.program.224.name}: ${sys.program.224.enabled}
225) ${sys.program.225.name}: ${sys.program.225.enabled}
226) ${sys.program.226.name}: ${sys.program.226.enabled}
227) ${sys.program.227.name}: ${sys.program.227.enabled}
228) ${sys.program.228.name}: ${sys.program.228.enabled}
229) ${sys.program.229.name}: ${sys.program.229.enabled}
230) ${sys.program.230.name}: ${sys.program.230.enabled}
231) ${sys.program.231.name}: ${sys.program.231.enabled}
232) ${sys.program.232.name}: ${sys.program.232.enabled}
233) ${sys.program.233.name}: ${sys.program.233.enabled}
234) ${sys.program.234.name}: ${sys.program.234.enabled}
235) ${sys.program.235.name}: ${sys.program.235.enabled}
236) ${sys.program.236.name}: ${sys.program.236.enabled}
237) ${sys.program.237.name}: ${sys.program.237.enabled}
238) ${sys.program.238.name}: ${sys.program.238.enabled}
239) ${sys.program.239.name}: ${sys.program.239.enabled}
240) ${sys.program.240.name}: ${sys.program.240.enabled}
241) ${sys.program.241.name}: ${sys.program.241.enabled}
242) ${sys.program.242.name}: ${sys.program.242.enabled}
243) ${sys.program.243.name}: ${sys.program.243.enabled}
244) ${sys.program.244.name}: ${sys.program.244.enabled}
245) ${sys.program.245.name}: ${sys.program.245.enabled}
246) ${sys.program.246.name}: ${sys.program.246.enabled}
247) ${sys.program.247.name}: ${sys.program.247.enabled}
248) ${sys.program.248.name}: ${sys.program.248.enabled}
249) ${sys.program.249.name}: ${sys.program.249.enabled}
250) ${sys.program.250.name}: ${sys.program.250.enabled}
251) ${sys.program.251.name}: ${sys.program.251.enabled}
252) ${sys.program.252.name}: ${sys.program.252.enabled}
253) ${sys.program.253.name}: ${sys.program.253.enabled}
254) ${sys.program.254.name}: ${sys.program.254.enabled}
255) ${sys.program.255.name}: ${sys.program.255.enabled}
256) ${sys.program.256.name}: ${sys.program.256.enabled}
257) ${sys.program.257.name}: ${sys.program.257.enabled}
258) ${sys.program.258.name}: ${sys.program.258.enabled}
259) ${sys.program.259.name}: ${sys.program.259.enabled}
260) ${sys.program.260.name}: ${sys.program.260.enabled}
261) ${sys.program.261.name}: ${sys.program.261.enabled}
262) ${sys.program.262.name}: ${sys.program.262.enabled}
263) ${sys.program.263.name}: ${sys.program.263.enabled}
264) ${sys.program.264.name}: ${sys.program.264.enabled}
265) ${sys.program.265.name}: ${sys.program.265.enabled}
266) ${sys.program.266.name}: ${sys.program.266.enabled}
267) ${sys.program.267.name}: ${sys.program.267.enabled}
268) ${sys.program.268.name}: ${sys.program.268.enabled}
269) ${sys.program.269.name}: ${sys.program.269.enabled}
270) ${sys.program.270.name}: ${sys.program.270.enabled}
271) ${sys.program.271.name}: ${sys.program.271.enabled}
272) ${sys.program.272.name}: ${sys.program.272.enabled}
273) ${sys.program.273.name}: ${sys.program.273.enabled}
274) ${sys.program.274.name}: ${sys.program.274.enabled}
275) ${sys.program.275.name}: ${sys.program.275.enabled}
276) ${sys.program.276.name}: ${sys.program.276.enabled}
277) ${sys.program.277.name}: ${sys.program.277.enabled}
278) ${sys.program.278.name}: ${sys.program.278.enabled}
279) ${sys.program.279.name}: ${sys.program.279.enabled}
280) ${sys.program.280.name}: ${sys.program.280.enabled}
281) ${sys.program.281.name}: ${sys.program.281.enabled}
282) ${sys.program.282.name}: ${sys.program.282.enabled}
283) ${sys.program.283.name}: ${sys.program.283.enabled}
284) ${sys.program.284.name}: ${sys.program.284.enabled}
285) ${sys.program.285.name}: ${sys.program.285.enabled}
286) ${sys.program.286.name}: ${sys.program.286.enabled}
287) ${sys.program.287.name}: ${sys.program.287.enabled}
288) ${sys.program.288.name}: ${sys.program.288.enabled}
289) ${sys.program.289.name}: ${sys.program.289.enabled}
290) ${sys.program.290.name}: ${sys.program.290.enabled}
291) ${sys.program.291.name}: ${sys.program.291.enabled}
292) ${sys.program.292.name}: ${sys.program.292.enabled}
293) ${sys.program.293.name}: ${sys.program.293.enabled}
294) ${sys.program.294.name}: ${sys.program.294.enabled}
295) ${sys.program.295.name}: ${sys.program.295.enabled}
296) ${sys.program.296.name}: ${sys.program.296.enabled}
297) ${sys.program.297.name}: ${sys.program.297.enabled}
298) ${sys.program.298.name}: ${sys.program.298.enabled}
299) ${sys.program.299.name}: ${sys.program.299.enabled}
300) ${sys.program.300.name}: ${sys.program.300.enabled}
301) ${sys.program.301.name}: ${sys.program.301.enabled}
302) ${sys.program.302.name}: ${sys.program.302.enabled}
303) ${sys.program.303.name}: ${sys.program.303.enabled}
304) ${sys.program.304.name}: ${sys.program.304.enabled}
305) ${sys.program.305.name}: ${sys.program.305.enabled}
306) ${sys.program.306.name}: ${sys.program.306.enabled}
307) ${sys.program.307.name}: ${sys.program.307.enabled}
308) ${sys.program.308.name}: ${sys.program.308.enabled}
309) ${sys.program.309.name}: ${sys.program.309.enabled}
310) ${sys.program.310.name}: ${sys.program.310.enabled}
311) ${sys.program.311.name}: ${sys.program.311.enabled}
312) ${sys.program.312.name}: ${sys.program.312.enabled}
313) ${sys.program.313.name}: ${sys.program.313.enabled}
314) ${sys.program.314.name}: ${sys.program.314.enabled}
315) ${sys.program.315.name}: ${sys.program.315.enabled}
316) ${sys.program.316.name}: ${sys.program.316.enabled}
317) ${sys.program.317.name}: ${sys.program.317.enabled}
318) ${sys.program.318.name}: ${sys.program.318.enabled}
319) ${sys.program.319.name}: ${sys.program.319.enabled}
320) ${sys.program.320.name}: ${sys.program.320.enabled}
321) ${sys.program.321.name}: ${sys.program.321.enabled}
322) ${sys.program.322.name}: ${sys.program.322.enabled}
323) ${sys.program.323.name}: ${sys.program.323.enabled}
324) ${sys.program.324.name}: ${sys.program.324.enabled}
325) ${sys.program.325.name}: ${sys.program.325.enabled}
326) ${sys.program.326.name}: ${sys.program.326.enabled}
327) ${sys.program.327.name}: ${sys.program.327.enabled}
328) ${sys.program.328.name}: ${sys.program.328.enabled}
329) ${sys.program.329.name}: ${sys.program.329.enabled}
330) ${sys.program.330.name}: ${sys.program.330.enabled}
331) ${sys.program.331.name}: ${sys.program.331.enabled}
332) ${sys.program.332.name}: ${sys.program.332.enabled}
333) ${sys.program.333.name}: ${sys.program.333.enabled}
334) ${sys.program.334.name}: ${sys.program.334.enabled}
335) ${sys.program.335.name}: ${sys.program.335.enabled}
336) ${sys.program.336.name}: ${sys.program.336.enabled}
337) ${sys.program.337.name}: ${sys.program.337.enabled}
338) ${sys.program.338.name}: ${sys.program.338.enabled}
339) ${sys.program.339.name}: ${sys.program.339.enabled}
340) ${sys.program.340.name}: ${sys.program.340.enabled}
341) ${sys.program.341.name}: ${sys.program.341.enabled}
342) ${sys.program.342.name}: ${sys.program.342.enabled}
343) ${sys.program.343.name}: ${sys.program.343.enabled}
344) ${sys.program.344.name}: ${sys.program.344.enabled}
345) ${sys.program.345.name}: ${sys.program.345.enabled}
346) ${sys.program.346.name}: ${sys.program.346.enabled}
347) ${sys.program.347.name}: ${sys.program.347.enabled}
348) ${sys.program.348.name}: ${sys.program.348.enabled}
349) ${sys.program.349.name}: ${sys.program.349.enabled}
350) ${sys.program.350.name}: ${sys.program.350.enabled}
351) ${sys.program.351.name}: ${sys.program.351.enabled}
352) ${sys.program.352.name}: ${sys.program.352.enabled}
353) ${sys.program.353.name}: ${sys.program.353.enabled}
354) ${sys.program.354.name}: ${sys.program.354.enabled}
355) ${sys.program.355.name}: ${sys.program.355.enabled}
356) ${sys.program.356.name}: ${sys.program.356.enabled}
357) ${sys.program.357.name}: ${sys.program.357.enabled}
358) ${sys.program.358.name}: ${sys.program.358.enabled}
359) ${sys.program.359.name}: ${sys.program.359.enabled}
360) ${sys.program.360.name}: ${sys.program.360.enabled}
361) ${sys.program.361.name}: ${sys.program.361.enabled}
362) ${sys.program.362.name}: ${sys.program.362.enabled}
363) ${sys.program.363.name}: ${sys.program.363.enabled}
364) ${sys.program.364.name}: ${sys.program.364.enabled}
365) ${sys.program.365.name}: ${sys.program.365.enabled}
366) ${sys.program.366.name}: ${sys.program.366.enabled}
367) ${sys.program.367.name}: ${sys.program.367.enabled}
368) ${sys.program.368.name}: ${sys.program.368.enabled}
369) ${sys.program.369.name}: ${sys.program.369.enabled}
370) ${sys.program.370.name}: ${sys.program.370.enabled}
371) ${sys.program.371.name}: ${sys.program.371.enabled}
372) ${sys.program.372.name}: ${sys.program.372.enabled}
373) ${sys.program.373.name}: ${sys.program.373.enabled}
374) ${sys.program.374.name}: ${sys.program.374.enabled}
375) ${sys.program.375.name}: ${sys.program.375.enabled}
376) ${sys.program.376.name}: ${sys.program.376.enabled}
377) ${sys.program.377.name}: ${sys.program.377.enabled}
378) ${sys.program.378.name}: ${sys.program.378.enabled}
379) ${sys.program.379.name}: ${sys.program.379.enabled}
380) ${sys.program.380.name}: ${sys.program.380.enabled}
381) ${sys.program.381.name}: ${sys.program.381.enabled}
382) ${sys.program.382.name}: ${sys.program.382.enabled}
383) ${sys.program.383.name}: ${sys.program.383.enabled}
384) ${sys.program.384.name}: ${sys.program.384.enabled}
385) ${sys.program.385.name}: ${sys.program.385.enabled}
386) ${sys.program.386.name}: ${sys.program.386.enabled}
387) ${sys.program.387.name}: ${sys.program.387.enabled}
388) ${sys.program.388.name}: ${sys.program.388.enabled}
389) ${sys.program.389.name}: ${sys.program.389.enabled}
390) ${sys.program.390.name}: ${sys.program.390.enabled}
391) ${sys.program.391.name}: ${sys.program.391.enabled}
392) ${sys.program.392.name}: ${sys.program.392.enabled}
393) ${sys.program.393.name}: ${sys.program.393.enabled}
394) ${sys.program.394.name}: ${sys.program.394.enabled}
395) ${sys.program.395.name}: ${sys.program.395.enabled}
396) ${sys.program.396.name}: ${sys.program.396.enabled}
397) ${sys.program.397.name}: ${sys.program.397.enabled}
398) ${sys.program.398.name}: ${sys.program.398.enabled}
399) ${sys.program.399.name}: ${sys.program.399.enabled}
400) ${sys.program.400.name}: ${sys.program.400.enabled}
401) ${sys.program.401.name}: ${sys.program.401.enabled}
402) ${sys.program.402.name}: ${sys.program.402.enabled}
403) ${sys.program.403.name}: ${sys.program.403.enabled}
404) ${sys.program.404.name}: ${sys.program.404.enabled}
405) ${sys.program.405.name}: ${sys.program.405.enabled}
406) ${sys.program.406.name}: ${sys.program.406.enabled}
407) ${sys.program.407.name}: ${sys.program.407.enabled}
408) ${sys.program.408.name}: ${sys.program.408.enabled}
409) ${sys.program.409.name}: ${sys.program.409.enabled}
410) ${sys.program.410.name}: ${sys.program.410.enabled}
411) ${sys.program.411.name}: ${sys.program.411.enabled}
412) ${sys.program.412.name}: ${sys.program.412.enabled}
413) ${sys.program.413.name}: ${sys.program.413.enabled}
414) ${sys.program.414.name}: ${sys.program.414.enabled}
415) ${sys.program.415.name}: ${sys.program.415.enabled}
416) ${sys.program.416.name}: ${sys.program.416.enabled}
417) ${sys.program.417.name}: ${sys.program.417.enabled}
418) ${sys.program.418.name}: ${sys.program.418.enabled}
419) ${sys.program.419.name}: ${sys.program.419.enabled}
420) ${sys.program.420.name}: ${sys.program.420.enabled}
421) ${sys.program.421.name}: ${sys.program.421.enabled}
422) ${sys.program.422.name}: ${sys.program.422.enabled}
423) ${sys.program.423.name}: ${sys.program.423.enabled}
424) ${sys.program.424.name}: ${sys.program.424.enabled}
425) ${sys.program.425.name}: ${sys.program.425.enabled}
426) ${sys.program.426.name}: ${sys.program.426.enabled}
427) ${sys.program.427.name}: ${sys.program.427.enabled}
428) ${sys.program.428.name}: ${sys.program.428.enabled}
429) ${sys.program.429.name}: ${sys.program.429.enabled}
430) ${sys.program.430.name}: ${sys.program.430.enabled}
431) ${sys.program.431.name}: ${sys.program.431.enabled}
432) ${sys.program.432.name}: ${sys.program.432.enabled}
433) ${sys.program.433.name}: ${sys.program.433.enabled}
434) ${sys.program.434.name}: ${sys.program.434.enabled}
435) ${sys.program.435.name}: ${sys.program.435.enabled}
436) ${sys.program.436.name}: ${sys.program.436.enabled}
437) ${sys.program.437.name}: ${sys.program.437.enabled}
438) ${sys.program.438.name}: ${sys.program.438.enabled}
439) ${sys.program.439.name}: ${sys.program.439.enabled}
440) ${sys.program.440.name}: ${sys.program.440.enabled}
441) ${sys.program.441.name}: ${sys.program.441.enabled}
442) ${sys.program.442.name}: ${sys.program.442.enabled}
443) ${sys.program.443.name}: ${sys.program.443.enabled}
444) ${sys.program.444.name}: ${sys.program.444.enabled}
445) ${sys.program.445.name}: ${sys.program.445.enabled}
446) ${sys.program.446.name}: ${sys.program.446.enabled}
447) ${sys.program.447.name}: ${sys.program.447.enabled}
448) ${sys.program.448.name}: ${sys.program.448.enabled}
449) ${sys.program.449.name}: ${sys.program.449.enabled}
450) ${sys.program.450.name}: ${sys.program.450.enabled}
451) ${sys.program.451.name}: ${sys.program.451.enabled}
452) ${sys.program.452.name}: ${sys.program.452.enabled}
453) ${sys.program.453.name}: ${sys.program.453.enabled}
454) ${sys.program.454.name}: ${sys.program.454.enabled}
455) ${sys.program.455.name}: ${sys.program.455.enabled}
456) ${sys.program.456.name}: ${sys.program.456.enabled}
457) ${sys.program.457.name}: ${sys.program.457.enabled}
458) ${sys.program.458.name}: ${sys.program.458.enabled}
459) ${sys.program.459.name}: ${sys.program.459.enabled}
460) ${sys.program.460.name}: ${sys.program.460.enabled}
461) ${sys.program.461.name}: ${sys.program.461.enabled}
462) ${sys.program.462.name}: ${sys.program.462.enabled}
463) ${sys.program.463.name}: ${sys.program.463.enabled}
464) ${sys.program.464.name}: ${sys.program.464.enabled}
465) ${sys.program.465.name}: ${sys.program.465.enabled}
466) ${sys.program.466.name}: ${sys.program.466.enabled}
467) ${sys.program.467.name}: ${sys.program.467.enabled}
468) ${sys.program.468.name}: ${sys.program.468.enabled}
469) ${sys.program.469.name}: ${sys.program.469.enabled}
470) ${sys.program.470.name}: ${sys.program.470.enabled}
471) ${sys.program.471.name}: ${sys.program.471.enabled}
472) ${sys.program.472.name}: ${sys.program.472.enabled}
473) ${sys.program.473.name}: ${sys.program.473.enabled}
474) ${sys.program.474.name}: ${sys.program.474.enabled}
475) ${sys.program.475.name}: ${sys.program.475.enabled}
476) ${sys.program.476.name}: ${sys.program.476.enabled}
477) ${sys.program.477.name}: ${sys.program.477.enabled}
478) ${sys.program.478.name}: ${sys.program.478.enabled}
479) ${sys.program.479.name}: ${sys.program.479.enabled}
480) ${sys.program.480.name}: ${sys.program.480.enabled}
481) ${sys.program.481.name}: ${sys.program.481.enabled}
482) ${sys.program.482.name}: ${sys.program.482.enabled}
483) ${sys.program.483.name}: ${sys.program.483.enabled}
484) ${sys.program.484.name}: ${sys.program.484.enabled}
485) ${sys.program.485.name}: ${sys.program.485.enabled}
486) ${sys.program.486.name}: ${sys.program.486.enabled}
487) ${sys.program.487.name}: ${sys.program.487.enabled}
488) ${sys.program.488.name}: ${sys.program.488.enabled}
489) ${sys.program.489.name}: ${sys.program.489.enabled}
490) ${sys.program.490.name}: ${sys.program.490.enabled}
491) ${sys.program.491.name}: ${sys.program.491.enabled}
492) ${sys.program.492.name}: ${sys.program.492.enabled}
493) ${sys.program.493.name}: ${sys.program.493.enabled}
494) ${sys.program.494.name}: ${sys.program.494.enabled}
495) ${sys.program.495.name}: ${sys.program.495.enabled}
496) ${sys.program.496.name}: ${sys.program.496.enabled}
497) ${sys.program.497.name}: ${sys.program.497.enabled}
498) ${sys.program.498.name}: ${sys.program.498.enabled}
499) ${sys.program.499.name}: ${sys.program.499.enabled}
500) ${sys.program.500.name}: ${sys.program.500.enabled}
For my system, the email sent is:
1) My Programs: True
2) Query All: True
3) OWLH_Notify: True
4) OWLink Health: True
5) OWLH_Pulse: True
6) Thermostat: True
7) Set Evening Cool: True
 Set Evening Heat: True
9) Set Morning Cool: True
10) Set Morning Heat: True
11) Evening Wait Timer: True
12) Set Evening: True
13) New Cooling Time: False
14) Set Morning: True
15) Recirc: True
16) Equalize: True
17) Saftey: True
18) Set Cooling: True
19) Set Cooling 60: True
20) Set Cooling 61: True
21) Set Cooling 62: True
22) Set Cooling 63: True
23) Set Cooling 64: True
24) Set Cooling 65: True
25) Set Cooling 66: True
26) HVAC Run Time: True
27) Update Attic: True
28) Garage Door Status: True
29) Garage Door: True
30) Update Attic Back: True
31) Toggle Fan: True
32) Set Cooling 67: True
33) Humidity: True
34) Update Garage: True
35) OWLH_Notify_RTN: False
36) OWLH_Pulse_RTN: True
37) Set Cooling 68: True
38) Set Cooling 69: True
39) Cooling SP: True
40) Cooling Current SP 59: True
41) Cooling Current SP 60: True
42) Update Office: True
43) Update Living Room: True
44) Update Khloe Room: True
45) Cooling Current SP 61: True
46) Cooling Current SP 62: True
47) Cooling Current SP 63: True
48) Cooling Current SP 64: True
49) Cooling Current SP 65: True
50) Cooling Current SP 66: True
51) Cooling Current SP 67: True
52) Cooling Current SP 68: True
53) Cooling Current SP 69: True
54) Cooling Current SP 70: True
55) Cooling Current SP 71: True
56) Cooling Current SP 72: True
57) Cooling Current SP 73: True
58) Cooling Current SP 74: True
59) Cooling Current SP 75: True
60) Cooling Current SP 76: True
61) Cooling Current SP 77: True
62) Cooling Current SP 78: True
63) Cooling Current SP 79: True
64) Cooling Current SP 80: True
65) Cooling Current SP 81: True
66) RT Cooling: True
67) Set Cooling 70: True
68) Set Cooling 71: True
69) Set Cooling 72: True
70) Set Cooling 73: True
71) Set Cooling 74: True
72) Set Cooling 75: True
73) Set Cooling 76: True
74) Set Cooling 77: True
75) Set Cooling 78: True
76) Set Cooling 79: True
77) Set Cooling 80: True
78) Cooling Current Update: True
79) Heating Current Update: True
80) Set Cooling Update: True
81) Adjust Cooling Up: True
82) Adjust Cooling Down: True
83) Set Heating: True
84) Set Heating 61: True
85) Set Heating 60: True
86) Set Heating 62: True
87) Set Heating 63: True
88) Set Heating 64: True
89) Set Heating 65: True
90) Set Heating 66: True
91) Set Heating 67: True
92) Set Heating 68: True
93) Set Heating 69: True
94) Set Heating 70: True
95) Set Heating 71: True
96) Set Heating 72: True
97) Set Heating 73: True
98) Set Heating 74: True
99) Set Heating 75: True
100) Set Heating 76: True
101) Set Heating 77: True
102) Set Heating 78: True
103) Set Heating 79: True
104) Set Heating 80: True
105) Set Heating Update: True
106) Adjust Heating Down: True
107) Adjust Heating Up: True
108) Humidity Notify: True
109) Network: True
110) MaddBomber Start: True
111) MaddBomber Sleep: True
112) LizPC Sleep: True
113) LizPC Start: True
114) Xmas Lights: True
115) Xmas Tree: True
116) New Program: True
117) program[117]: program[117]
118) program[118]: program[118]
119) program[119]: program[119]
120) program[120]: program[120]
121) program[121]: program[121]
122) program[122]: program[122]
123) program[123]: program[123]
124) program[124]: program[124]
125) program[125]: program[125]
126) program[126]: program[126]
127) program[127]: program[127]
128) program[128]: program[128]
129) program[129]: program[129]
130) program[130]: program[130]
131) program[131]: program[131]
132) program[132]: program[132]
133) program[133]: program[133]
134) program[134]: program[134]
135) program[135]: program[135]
136) program[136]: program[136]
137) RT Heating: True
138) RT Fan: True
139) RT Off: True
140) RT Cooling at 6pm: True
141) RT Daily Email: True
142) New Program: True
143) Heating Current SP 59: True
144) Heating Current SP 60: True
145) Heating Current SP 61: True
146) Heating Current SP 62: True
147) Heating Current SP 63: True
148) Heating Current SP 64: True
149) Heating Current SP 65: True
150) Heating Current SP 66: True
151) Heating Current SP 67: True
152) Heating Current SP 68: True
153) Heating Current SP 69: True
154) Heating Current SP 70: True
155) Heating Current SP 71: True
156) Heating Current SP 72: True
157) Heating Current SP 73: True
158) Heating Current SP 74: True
159) Heating Current SP 75: True
160) Heating Current SP 76: True
161) Heating Current SP 77: True
162) Heating Current SP 78: True
163) Heating Current SP 79: True
164) Heating Current SP 80: True
165) Heating Current SP 81: True
166) Heating SP: True
167) program[167]: program[167]
168) program[168]: program[168]
169) program[169]: program[169]
170) program[170]: program[170]
171) program[171]: program[171]
172) program[172]: program[172]
173) program[173]: program[173]
174) program[174]: program[174]
175) program[175]: program[175]
176) program[176]: program[176]
177) program[177]: program[177]
178) program[178]: program[178]
179) program[179]: program[179]
180) program[180]: program[180]
181) program[181]: program[181]
182) program[182]: program[182]
183) program[183]: program[183]
184) program[184]: program[184]
185) program[185]: program[185]
186) program[186]: program[186]
187) program[187]: program[187]
188) program[188]: program[188]
189) program[189]: program[189]
190) program[190]: program[190]
191) program[191]: program[191]
192) program[192]: program[192]
193) program[193]: program[193]
194) program[194]: program[194]
195) program[195]: program[195]
196) program[196]: program[196]
197) program[197]: program[197]
198) program[198]: program[198]
199) program[199]: program[199]
200) program[200]: program[200]
201) program[201]: program[201]
202) program[202]: program[202]
203) program[203]: program[203]
204) program[204]: program[204]
205) program[205]: program[205]
206) program[206]: program[206]
207) program[207]: program[207]
208) program[208]: program[208]
209) program[209]: program[209]
210) program[210]: program[210]
211) program[211]: program[211]
212) program[212]: program[212]
213) program[213]: program[213]
214) program[214]: program[214]
215) program[215]: program[215]
216) program[216]: program[216]
217) program[217]: program[217]
218) program[218]: program[218]
219) program[219]: program[219]
220) program[220]: program[220]
221) program[221]: program[221]
222) program[222]: program[222]
223) program[223]: program[223]
224) program[224]: program[224]
225) program[225]: program[225]
226) program[226]: program[226]
227) program[227]: program[227]
228) program[228]: program[228]
229) program[229]: program[229]
230) program[230]: program[230]
231) program[231]: program[231]
232) program[232]: program[232]
233) program[233]: program[233]
234) program[234]: program[234]
235) program[235]: program[235]
236) program[236]: program[236]
237) program[237]: program[237]
238) program[238]: program[238]
239) program[239]: program[239]
240) program[240]: program[240]
241) program[241]: program[241]
242) program[242]: program[242]
243) program[243]: program[243]
244) program[244]: program[244]
245) program[245]: program[245]
246) program[246]: program[246]
247) program[247]: program[247]
248) program[248]: program[248]
249) program[249]: program[249]
250) program[250]: program[250]
251) program[251]: program[251]
252) program[252]: program[252]
253) program[253]: program[253]
254) program[254]: program[254]
255) program[255]: program[255]
256) program[256]: program[256]
257) program[257]: program[257]
258) program[258]: program[258]
259) program[259]: program[259]
260) program[260]: program[260]
261) program[261]: program[261]
262) program[262]: program[262]
263) program[263]: program[263]
264) program[264]: program[264]
265) program[265]: program[265]
266) program[266]: program[266]
267) program[267]: program[267]
268) program[268]: program[268]
269) program[269]: program[269]
270) program[270]: program[270]
271) program[271]: program[271]
272) program[272]: program[272]
273) program[273]: program[273]
274) program[274]: program[274]
275) program[275]: program[275]
276) program[276]: program[276]
277) program[277]: program[277]
278) program[278]: program[278]
279) program[279]: program[279]
280) program[280]: program[280]
281) program[281]: program[281]
282) program[282]: program[282]
283) program[283]: program[283]
284) program[284]: program[284]
285) program[285]: program[285]
286) program[286]: program[286]
287) program[287]: program[287]
288) program[288]: program[288]
289) program[289]: program[289]
290) program[290]: program[290]
291) program[291]: program[291]
292) program[292]: program[292]
293) program[293]: program[293]
294) program[294]: program[294]
295) program[295]: program[295]
296) program[296]: program[296]
297) program[297]: program[297]
298) program[298]: program[298]
299) program[299]: program[299]
300) program[300]: program[300]
301) program[301]: program[301]
302) program[302]: program[302]
303) program[303]: program[303]
304) program[304]: program[304]
305) program[305]: program[305]
306) program[306]: program[306]
307) program[307]: program[307]
308) program[308]: program[308]
309) program[309]: program[309]
310) program[310]: program[310]
311) program[311]: program[311]
312) program[312]: program[312]
313) program[313]: program[313]
314) program[314]: program[314]
315) program[315]: program[315]
316) program[316]: program[316]
317) program[317]: program[317]
318) program[318]: program[318]
319) program[319]: program[319]
320) program[320]: program[320]
321) program[321]: program[321]
322) program[322]: program[322]
323) program[323]: program[323]
324) program[324]: program[324]
325) program[325]: program[325]
326) program[326]: program[326]
327) program[327]: program[327]
328) program[328]: program[328]
329) program[329]: program[329]
330) program[330]: program[330]
331) program[331]: program[331]
332) program[332]: program[332]
333) program[333]: program[333]
334) program[334]: program[334]
335) program[335]: program[335]
336) program[336]: program[336]
337) program[337]: program[337]
338) program[338]: program[338]
339) program[339]: program[339]
340) program[340]: program[340]
341) program[341]: program[341]
342) program[342]: program[342]
343) program[343]: program[343]
344) program[344]: program[344]
345) program[345]: program[345]
346) program[346]: program[346]
347) program[347]: program[347]
348) program[348]: program[348]
349) program[349]: program[349]
350) program[350]: program[350]
351) program[351]: program[351]
352) program[352]: program[352]
353) program[353]: program[353]
354) program[354]: program[354]
355) program[355]: program[355]
356) program[356]: program[356]
357) program[357]: program[357]
358) program[358]: program[358]
359) program[359]: program[359]
360) program[360]: program[360]
361) program[361]: program[361]
362) program[362]: program[362]
363) program[363]: program[363]
364) program[364]: program[364]
365) program[365]: program[365]
366) program[366]: program[366]
367) program[367]: program[367]
368) program[368]: program[368]
369) program[369]: program[369]
370) program[370]: program[370]
371) program[371]: program[371]
372) program[372]: program[372]
373) program[373]: program[373]
374) program[374]: program[374]
375) program[375]: program[375]
376) program[376]: program[376]
377) program[377]: program[377]
378) program[378]: program[378]
379) program[379]: program[379]
380) program[380]: program[380]
381) program[381]: program[381]
382) program[382]: program[382]
383) program[383]: program[383]
384) program[384]: program[384]
385) program[385]: program[385]
386) program[386]: program[386]
387) program[387]: program[387]
388) program[388]: program[388]
389) program[389]: program[389]
390) program[390]: program[390]
391) program[391]: program[391]
392) program[392]: program[392]
393) program[393]: program[393]
394) program[394]: program[394]
395) program[395]: program[395]
396) program[396]: program[396]
397) program[397]: program[397]
398) program[398]: program[398]
399) program[399]: program[399]
400) program[400]: program[400]
401) program[401]: program[401]
402) program[402]: program[402]
403) program[403]: program[403]
404) program[404]: program[404]
405) program[405]: program[405]
406) program[406]: program[406]
407) program[407]: program[407]
408) program[408]: program[408]
409) program[409]: program[409]
410) program[410]: program[410]
411) program[411]: program[411]
412) program[412]: program[412]
413) program[413]: program[413]
414) program[414]: program[414]
415) program[415]: program[415]
416) program[416]: program[416]
417) program[417]: program[417]
418) program[418]: program[418]
419) program[419]: program[419]
420) program[420]: program[420]
421) program[421]: program[421]
422) program[422]: program[422]
423) program[423]: program[423]
424) program[424]: program[424]
425) program[425]: program[425]
426) program[426]: program[426]
427) program[427]: program[427]
428) program[428]: program[428]
429) program[429]: program[429]
430) program[430]: program[430]
431) program[431]: program[431]
432) program[432]: program[432]
433) program[433]: program[433]
434) program[434]: program[434]
435) program[435]: program[435]
436) program[436]: program[436]
437) program[437]: program[437]
438) program[438]: program[438]
439) program[439]: program[439]
440) program[440]: program[440]
441) program[441]: program[441]
442) program[442]: program[442]
443) program[443]: program[443]
444) program[444]: program[444]
445) program[445]: program[445]
446) program[446]: program[446]
447) program[447]: program[447]
448) program[448]: program[448]
449) program[449]: program[449]
450) program[450]: program[450]
451) program[451]: program[451]
452) program[452]: program[452]
453) program[453]: program[453]
454) program[454]: program[454]
455) program[455]: program[455]
456) program[456]: program[456]
457) program[457]: program[457]
458) program[458]: program[458]
459) program[459]: program[459]
460) program[460]: program[460]
461) program[461]: program[461]
462) program[462]: program[462]
463) program[463]: program[463]
464) program[464]: program[464]
465) program[465]: program[465]
466) program[466]: program[466]
467) program[467]: program[467]
468) program[468]: program[468]
469) program[469]: program[469]
470) program[470]: program[470]
471) program[471]: program[471]
472) program[472]: program[472]
473) program[473]: program[473]
474) program[474]: program[474]
475) program[475]: program[475]
476) program[476]: program[476]
477) program[477]: program[477]
478) program[478]: program[478]
479) program[479]: program[479]
480) program[480]: program[480]
481) program[481]: program[481]
482) program[482]: program[482]
483) program[483]: program[483]
484) program[484]: program[484]
485) program[485]: program[485]
486) program[486]: program[486]
487) program[487]: program[487]
488) program[488]: program[488]
489) program[489]: program[489]
490) program[490]: program[490]
491) program[491]: program[491]
492) program[492]: program[492]
493) program[493]: program[493]
494) program[494]: program[494]
495) program[495]: program[495]
496) program[496]: program[496]
497) program[497]: program[497]
498) program[498]: program[498]
499) program[499]: program[499]
500) program[500]: program[500]
Please note, the ISY did not like me going to 1000.
I should also add that FOLDERS are included in these numbers as well.
I don't know why the wiki does not include all of the custom notification variable subs. I am curious as to what else can be subbed in that I don't know about.
For some reason I can't get that to work. The carriage returns are screwing it up. If I delete the carriage returns it works. Are you able to have it send with carriage returns? I guess I'll have to go through and delete all of them?
EDIT: I used MS word to replace all the line breaks with a "*". Then after I got the email I did the process in reverse putting line breaks back in. So I'm good now. But I don't understand how yours works with the line breaks in place and mine doesn't.
EDIT AGAIN: If you just convert the hex value on the program summary page to integer it works fine without having to do that gigantic email For example, 001B is program 27.
Do you mean variable as in integer/state variable? If so can you give 1 examble of the format please? I have tried every way I can think of. Also, what do you mean by "edited it to Enabled?
Tim
I figured there was a conversion somewhere.
As for the return, yes mine has them just fine. It is likely lost in the cut/paste process from the forums. I actually created an excel sheet to do all the numbers, and then copied those rows directly into the notification email. The email I got was 1 line per program.
For the forums I copied it from the program and into here.
Tim
We are only talking about in the notification email settings. Not in an actual program.
When I say edited it to enable, in the notification program I hit add variable (the one with the name) and then just guessed that changing the name part to enabled would work.
Yes, in notification email settings.
After hitting add variable this appears in the body ${var.1.91}. How did you modify that line to show the variable Name in the email/text?
I pasted it into MS word and turned on the feature that shows all hidden characters. What I got from you was line breaks at the end of each line and a paragraph break at the end. Both line breaks and paragraph breaks had to be deleted for it to work. Even if I manually typed it in with a "return" it simply didn't work. I don't get how you can do it but I can't.
Just delete type it in manually ${sys.program.name} Or delete the var.1.91 and replace it.
No, what I am asking is using the variable sub. on state/int variables instead of programs. For instance ${sys.program.1.name} will print the program name in the email, what will do the same for state/int variables? I have tried ${sys.var.1-1.name} and ${sys.variable.1-1.name} etc but cannot seem to find the right command.
If it can be done at all, I would expect ${sys.var.1.1.name}
Yeah that was my thinking as well but every way I tried it didn't work, thats why I asked maddbomber83 for clarification on whether he was talking about using the variable subst. on variables and programs. Still not sure if he is or not.
