December 12, 201312 yr Are the ISY "Fast On" and "Fast Off" control conditions equivalent to registering a double-tap ON or OFF? For example, a double-on tap on one of my Switchlinc not only turns on the connect light but also triggers and event or scene? Same for double-off tap. Thanks.
December 12, 201312 yr Yes. Thats exactly what the Double Tap is. You can watch for FastOn or FastOff control events coming from a device and take action based on receipt of either as well as Fade Up, Fade Down, Fade Stop, Bright, Dim, On or Off. -Xathros
