High Wattage Dimmer
I have a 4 way circuit that requires a high wattage dimmer. I know the light will need to be controlled by the 2477DH, but, My question is..... Can I control the high wattage dimmer with standard dimmer (600 W) dimmer switches in the other 2 positions?
I think the answer is yes, but I don't want to miss something obvious if the codes are sent in a different manner.
"Can I control the high wattage dimmer with standard dimmer (600 W) dimmer switches in the other 2 positions?"
Certainly. The high wattage dimmer can even be controlled from Relay based devices. The issue with using a SwitchLinc Relay is the Status LEDs on a Relay only show Off and full On. The Relay can brighten and dim the high wattage dimmer, the Status LEDs just do not reflect the bright/dim level of the high wattage dimmer.
