Enable disable an program issue
I have something like that :
From Sunset
To Sunrise (next day)
And $sAlarmZ14_GarageDoorPaco is 1
Or $sAlarmZ13_GarageDoorHoney is 1
Enable Program 'Garage Scene HallWay'
Wait 5 minutes
Disable Program 'Garage Scene HallWay'
and an other : Program 'Garage Scene HallWay'
$sAlarmZ3_GarageDoorHouse is 1
Set Scene '1st Floor / Entrance Ceiling' Fade Up
Set Scene '1st Floor / Entrance HallWay' Fade Up
Wait 4 minutes
Set Scene '1st Floor / Entrance Ceiling' Fade Down
Set Scene '1st Floor / Entrance HallWay' Fade Down
First issue is with the program 'Garage Scene HallWay' he turn light on, but never turn off the scene!!!
Second issue is the first program, he works for enable the 2nd program but never disable it after time elapsed !
When the statements after a Wait are not executed it means the If condition changes while in the Wait. The ISY terminates the Wait, reevaluates the If and executes the Else clause because the If is now False. The statements after the Wait never get executed.
There is also a problem with the If clause independent of the above. It needs some parens.
From Sunset
And (
Wait 5 minutes
A simple solution is to put the above into two programs. The Then section invokes Program 2 which has the Enable/Wait/Disable. There are other approaches as well.
Ok now I have 3 program
From Sunset
And (
Enable Program 'Garage Door House Contact'
Wait 1 minute
Disable Program 'Garage Door House Contact'
Run Program 'Scene HallWay' (Then Path)
Wait 15 seconds
It's working but if the door garage close before I open the door ($sAlarmZ3_GarageDoorHouse), the program 'Garage Door House Contact' doesn't start !
