EZIO4 Device Settings and upload
I have been using Indigo on a Mac to control my many devices and wanted a stand alone box for a controller. The ISY994i seemed to be what I wanted but now I am having trouble with a couple of programming issues.
In this post, I am wondering how to edit and upload the Device Settings for an EZIO4. There doesn't seem to be a way to do that using ISY99i. So, I have to use Indigo to do it but that is not what I want to do in the field where I don't have a Mac running Indigo.
Oliver
The output timers are the only thing yhat would be useful. The ISY does not support setting the output timers. The free Simplehomenet Utility Suite from Simplehomenet/Smartenit can be used on a windows system.
Thanks for the reply.
I also have an EZIO2X4 and need to set the analog trip points. Is this also not supported?
Oliver
The ISY does not support those Inputs in Analog mode. That would not only require setting the analog trip points, the Configuration Register would require management as well. The ISY does not know about the Analog aspects of the Configuration Register and would wipe out the settings.
