Want to run SmartPhone/PDA to view ISY-99i. How?
Ottermator
I want to be able to view my Insteon Network using my smartphone (AT&T Tilt with Windows Mobile 6 with the Esmertec JVM). When I run IE it tells me I need Java 2+. I tried Minimo it does work. I have yet to try Opera Mini. I read old posts about WEME not being supported. Is this true? Is there an HTNL version? Do I want that?:?
What exactly do I need to do to run ISY on my phone?
TIA
OMR-Mike
Are you trying to launch the Administrative Console? I don't believe that will run on mobile devices.
If you are running the latest ISY firmware, you'll have an HTML interface that you can use to control your devices & scenes. That should run fine on Windows Mobile 6.
According to the About window
I am running Insteon_UD99 v.1.0.0
Product ISY 99i(1020). Is this the latest?
How do I get to the HTML site?
Do I have to enable INternet Access?
TIA
OMR/Mike
Hi Mike,
Version 1.0.0 is the current release version for ISY-99i series. Beta version 2.6.4 is available here.
You will need the beta firmware to use the HTML page. Please read the notes and follow the instructions in the post linked above.
You will have to enable internet access if you wish to access ISY from outside your LAN.
Smartphone works great!
I forgot to mention the software upgrade was a snap!
However now that I go this far, I notice that the 2nd floor linked fine, but the first floor insteons didnt link at all. need to check this out.hmmmmmmmm.
OMR/Mike
      38.2k
      381.2k
