Custom Notices - devices with "0" in address not reporting
Hi All,
I have a custom notification set up to run that gives me current status on a hand full of devices. I have a bunch of 2441TH thermostats on this report. I have 4 thermostats that I cannot get the custom notifications to report on. The isy can see them and communicate with no issues. I just noticed that all four thermostats have a zero in the address at the leading digit in the second set. These are the actual address that are not working;
Basement ..... ${sys.node.24 07 6D 1.ST}
Bedroom 1 .....${sys.node.24 07 38 1.ST}
Bedroom 2 .....${sys.node.24 08 58 1.ST}
Bedroom 3 .....${sys.node.24 08 D7 1.ST}
I don't have any other devices with a zero in the address at this spot to test this out....
Has anyone run across this, is there a fix for this?
Will
Hi All,
Will
Hi Will-
Just omit the leading 0. Bedroom 3 .....${sys.node.24 8 D7 1.ST}
-Xathros
Form some reason the ZERO gets removed. This has been a sore spot for years. Why a ZERO is removed from a string is something that has never been explained.
Sent from my GT-P5210 using Tapatalk
Usually you drop the leading zero, at least for REST commands, etc.
Try:
Basement ..... ${sys.node.24 7 6D 1.ST}
Bedroom 1 .....${sys.node.24 7 38 1.ST}
Bedroom 2 .....${sys.node.24 8 58 1.ST}
Thank you for the responses!! It worked by dropping the zero.
