Android Mobilinc MultiDevice Help
Hi,
I am using the Android version of Mobilinc Pro on my phone and it works really well. I have purchased a second ISY for my weekend getaway condo. So I have one ISY at my primary residence and this new one at the condo. What I can't seem to figure out is how to add a second profile in Mobilinc. When you go into Active Profile, under Selected Profile, it shows Default from the drop down box, I don't see anywhere in which to add a second Profile to add the settings specific to my second ISY. Any help would be appreciated. I also have an Ipad version so haven't tackled that yet to see if it differs or not but will be shortly. Any help would be appreciated.
Hi PalChgo,
From our Q and A page: http://mobilinc.com/support/commonquestions/
"Does MobiLinc support multiple controllers?"
Yes! MobiLinc supports a virtual unlimited number of ISY/SmartLinc controllers.
For iOS devices, go to My Settings->Selected Profile. Tap the "+" button to add in another profile.
For Android devices, go to My Settings. Perform a long press on the Selected Profile row and select "Create a new profile".
Please let me know if I can help answer any other questions for you.
Wes
  • 4 weeks later...
Hi Wes, thanks for the answer earlier. It worked out for me. I do however have a new problem and do not know if its related or not as I don't have a good handle on when this new problem started. I have tasker installed and I use it at the primary location to say "Time for Bed" and it shuts all the lights off. I don't use it that often so that's why I can't pinpoint a time when this stopped working. I went into tasker and got down to the mobilinc configuration for the individual command. It appears as if when I select "Scenes" or Devices there is nothing listed in the dropdown box. It shows the profile name the Event Type but the Scene is blank and remains blank even if I try changing to a device, program or scene. I tried deleting the second profile but that did not seem to help so I will be putting the second profile back in.
Steve
Hi Steve,
Tasker gets it list from MobiLinc. MobiLinc provides device/scene info based on what it has for that profile. Open MobiLinc and please confirm that for the profile selected in Tasker, MobiLinc has a full set of devices/scenes/etc.
Wes
Hi Wes
OK I think I see the problem. I setup tasker before I created the second profile a while back. While in tasker then mobilinc settings I had to switch to the second profile. From there I switched back to the original profile and then it brought up the scene pull down boxes with all my scenes. I had also deleted the second profile in mobilinc and then put it back in. Before I had put profile two back the drop down boxes would not work from tasker/mobilinc config settings. So that looks like a good workaround if the drop downs are missing.
Steve
