AT&T to end email-to-text ×
Switch turns on and off automatically
Panda88
Hi
I have a strange scenario. I have a switch located in the middle of my house and it turns the light on and off random.
I have tried to replaced the switch and both switches have the same issue. There are several other switches close by. The only special item I can see for this location is it is driving 6 parallel spots (75W) - Can it be related to the load - it seems to happen more often when light is dimmed.
What can I do to debug this problem? Any ideas?
thanks
Chris
What is the full switch Item number?
Is it in the same j-box with other Insteon devices where the load capacity is reduced due to additional heat?
I have tried 2334-222 and 2477D.
There are no other insteon in the same J-box.
I am contemplating to change to fluorescent sports (lower power)
Chris
The 450 watt load should be fine for either the KeypadLinc or SwitchLinc in a box by itself.
Are there any Programs which could be turning the current device On/Off?
Also a factory reset of the device to clear any X10 address with a Restore Device to rebuild link database is an option.
Note that dimmers are not rated for CFL devices.
