Geo Fence Light Control
The following program is set so that when I get home and its between sunrise and sunset the rear pole lamp goes on for 3 minutes and then shuts off.
However if I arrive home prior to sunset and remain home after sunset the program also triggers. Is there some way to avoid this.
I want it to trigger if I arrive home after sunset and not trigger if I arrive home before sunset and remain home.
$My_iphone_home is a geo fence variable controlled by Mobilinc on my iphone.
$My_iPhone_home is 1
And From Sunset
To Sunrise (next day)
Send Notification to 'Text Message' content 'My Home'
Set Scene 'Scenes / Outside Rear Pole Lamp' On
Wait 3 minute
Set Scene 'Scenes / Outside Rear Pole Lamp' Off
My first though was to create a second program and integer variable:
From sunset
To sunrise
Set integer variable 1
Set integer variable 0
Then replace the from sunset to sunrise in your program with the integer variable:
$myiphone home 1
And integer variable 1
My assumption is that your program is triggering at sunset. The question, then, is how to set up the program with the same conditions, but does not trigger at the from/to times. This is what I came up with:
From Sunset
run the programs in this folder
In the folder, add a program:
Wait 3 minute
TJF1960 version would work as well, I expect.
Beware....I expect your program has another hole. What happens if you leave home (or sunrise occurs) during the 3 minute wait? (hint: the light may not turn off.)
