Zone 3 status in ISY
shannong
My ISY only lists Output zones starting at 65. The onboard Output Zone 3 is a contact closure I want to use from ISY.
When it's active, it becomes populated in ISY for the Outputs of the Elk tab. When it turns off, it reflects that status. However, whenever a fresh connection is made to ISY it doesn't reappear. Also, I cannot select it in programs even when it is showing in the Elk tab.
Anyway to make it stay so I can trigger Output Zone 3 and build notifications?
Well, that was easy. You need to check the "Show" column in RP2.
Knowing it should work was all the motivation I needed to poke around more. Thanks for the info.
      37.6k
      376.2k
