ISY99 sends two emails instead of one
I have my ISY99 configured to send me an email based on some events. It always sends 2 copies of the email; both identical. I have upgraded to an ISY994, and it does the exact same thing. I am using the built-in email settings, as I wasn't able to get it to work with mine.
Anyone know why its sending 2 copies of the email? What do I have set wrong?
Post the Program sending the notification twice. It sounds like the Program is being invoked more than once. Right click on the Program name and select Copy to Clipboard. Paste in forum post.
I made a super-simple program to test the system, and found it did not send 2 copies of the email:
       Time is  2:57:00PM
       Send Notification to 'Vance GMAIL' content 'Presence is AT HOME'
However, where I am implementing, the code is a little more complicated:
       $Presence is 1
   And $Presence_JUST_CHANGED is 1
       $Presence_JUST_CHANGED  = 0
The way this works is the variable Presence indicates if we are at home or not, and it set using some other programs, based on a bunch of inputs, like time schedule, security alarm state (disarmed/home/away), motion detected in certain security alarm zones, etc. The security alarm is a Honeywell Vista which sends some X10 commands based on zone inputs. The ISY994 hears these and takes actions accordingly.
Since I want for some certain things to happen "right after" the state of the Presence variable changes, I added another variable called Presence_JUST_CHANGED which is changed to 1 when the Presence state changes, and if not changed back by another program (like this one), will time-out automatically.
Some how, the upper program sends 1 email like its supposed to, but the bottom program sends 2. Any ideas?
Look at the other Programs that are setting the Variables. The Variable combination must be set to the state that drives the Then clause twice to get two emails.
I was thinking that, but I the IF contains Presence_JUST_CHANGED=1, and the THEN changes Presence_JUST_CHANGED=0. I thought that would prevent it from running more than once.
It would if that is all that was happening. The Variables are being changed such that the Program is triggered twice. The test you ran confirms a Notify sends one email. The only way for two emails to be sent is to trigger the Program twice. That means that the Variables are both set to 1 two times.
