what can interrupt a WAIT command
I have a question. If the following program was running because, say, the thermostat had a temperature of 80 degrees:
         Status  'Thermostat' > 78° (Temperature)
       Wait  5 minutes
       Set 'Thermostat' 75° (Cool Setpoint)
And 2 minutes into the WAIT command the temperature went up to 81 degrees, would the program restart itself and the 5 minute wait period? Or would it continue to run through the original 5 minute WAIT?
The program would restart itself (and the 5 minute wait) because the Temperature status of 'Thermostat' would have changed.
If you don't want it to stop, then you could do the following:
   And Program 'Change Setpoint' is False
       Run Program 'Change Setpoint' (Then Path)
'Change Setpoint'
       Wait  5 minutes
       Run Program 'Change Setpoint' (Else path)
Thanks... I had a feeling that might be the case.
