How to check current status in program before changing
I could not find an example of how to check the current status of a dimmer switch before changing it. In a sunset program I would like to check and see if the dimmer is on before I turn it on automatically via the sunset program. This is in case someone has the illumination already set to their liking and I don't want to change the illumination already established in the case it's on.
Hi rrathke-
Try something like this:
  Status Dimmer is Off
  Set Dimmer On
Hope this helps.
-Xathros
This then triggers the program when switch is press and turns it back on creating a unwanted loop.
Hehe - Yep. Sorry - Missed a step:
  And Control Dimmer is not Switched Off
  Set Dimmer On
If looking to do something at Sunset if the device is Off ....
       Time is Sunset
   And Status  'SwitchLinc Dimmer' is Off
       Set 'SwitchLinc Dimmer DB' On
Xathros
It worked, now I understand.....Thanks!!
Anytime. Happy to help. Sorry about the omission on my first response.
-Xathros
